bluemadness14
 Mikuni carb
I have a 35 hp mud buddy with heads cam exhaust. Just added the mikuni and it runs great sitting in the driveway. When I take it to the water is runs awesome for about 3 minutes. Then screws up. It runs fine from 1/4 throttle to wot but from idle if I give it throttle it stumbles a couple seconds and then goes. Also when I shut it off its hard to get back started. Anyone have any idea what this could be?
Sent from my SAMSUNG-SM-G890A using Tapatalk
| Wed May 25, 2016 12:40 pm |
flint87
 Re: Mikuni carb
Sounds like fuel delivery but there's a million things to check. What jetting are you running?
| Wed May 25, 2016 4:29 pm |
bluemadness14
 Re: Mikuni carb
I ordered it from the boat dr. I'm thinking he said 165 and 20
| Wed May 25, 2016 5:18 pm |
flint87
 Re: Mikuni carb
| Wed May 25, 2016 5:54 pm |
bluemadness14
 Re: Mikuni carb
The tank vent is open and I jus replaced the fuel lines. I am running a fuel water separator. I'm not sure if that matters and it is a vacuum pump
| Wed Jun 01, 2016 5:05 am |
MaXXis85
 Re: Mikuni carb
I would adjust the ACC pump to barely any gap, then make sure it is spraying on the jet needle. Needle nose pliers can coax it back into positon.
| Wed Jun 01, 2016 6:55 am |
flint87
 Re: Mikuni carb
Not to hijack but is there any problem with the gap being too closed? Mine is spraying fuel into the slide for a split second as soon as I hit the throttle
| Wed Jun 01, 2016 11:30 am |
krazo
Joined: Thu Sep 06, 2012 8:44 pm Posts: 667 Location: SE Bama
 Re: Mikuni carb
If the a/f isn't set right it could cause this too. Did you read the manual and set everything before you run the motor?
_________________ 1754 prodigy- stage 2 GTR
| Wed Jun 01, 2016 1:10 pm |
bluemadness14
 Re: Mikuni carb
Yes I set everything like the manual said. Also called the boat dr and he said make sure the acc pump is spraying in the right spot and it's also good
| Wed Jun 01, 2016 2:00 pm |
cb5331
 Re: Mikuni carb
| Wed Jun 01, 2016 2:03 pm |
bluemadness14
 Re: Mikuni carb
Does the acc pump need to be hitting the needle when it sprays or just going by it
| Wed Jun 01, 2016 3:56 pm |
flint87
 Re: Mikuni carb
| Wed Jun 01, 2016 4:23 pm |
bluemadness14
 Re: Mikuni carb
Does anyone know what I should adjust my valves to? I have cam heads exhaust and mikuni
| Thu Jun 02, 2016 7:20 pm |
Russ
 Re: Mikuni carb
Ask the person/company that sold you the cam. Also, you could read the 7000 posts on the subject on this forum. There's a discussion that's been happening the last week or two concerning that very thing.
| Thu Jun 02, 2016 8:03 pm |
MaXXis85
 Re: Mikuni carb
Acc pump has to hit the jet needled to splatter the fuel to help atomize it.
| Fri Jun 03, 2016 5:46 am |
