MudBuddy77
Joined: Mon Oct 03, 2011 5:56 pm Posts: 298 Location: Caddo lake
 Gtr losing power? Help me please
My motor is all stock and on a gatortrax boat. Went for about an hour long trip through the backwaters. I had coolers and other stuff, my wife and two kids who are 2 and 6, and 2 other kids in the boat. Weighing a good amount I went with it and surprisingly the boat was doing fairly good running around 23-24 or so. About half way through the trip, while hitting my same rpms as before (4000) I was only running 16-17. I ended up stopping at some point, and got back on plane and it ran like a scolded dog back at 23-24. What Happened? What could it be? Is there something out of adjustment? It has about 100 hrs on it.
| Sat Jul 09, 2016 11:02 pm |
brycecheramie
 Re: Gtr losing power? Help me please
Check valves, make sure fuel is good, check for air leaks in the fuel line. Check for air leaks in the intake/Carb. I don't know what causes what you are describing.
But those are the first things I'd check.
| Sat Jul 09, 2016 11:06 pm |
Will C
If your rpms stayed the same then i cant call that a loss of power. Any chance it just had a bit grass etc stuck on shaft in front of prop?
| Sun Jul 10, 2016 12:34 am |
BERNIE255
Joined: Sun Jun 16, 2013 4:43 pm Posts: 1381 Location: Avoyelles Parish/ Marksville LA
Maybe deeper water wen it was running slow?
| Sun Jul 10, 2016 12:36 am |
brycecheramie
Both of these sound pretty good too ^^
| Sun Jul 10, 2016 1:01 am |
cb5331
Deeper water, rougher water, current, wind...something that was just enough to keep you from getting completely up on plane. Probably not an issue with the motor.
| Sun Jul 10, 2016 8:57 am |
MudBuddy77
Thanks guys. I'm hoping no issues. I guess I should be able to tell for sure next time I run it without a heavy load.
| Sun Jul 10, 2016 9:40 am |
brycecheramie
| Sun Jul 10, 2016 4:18 pm |
MudBuddy77
Haha. Still burnin slow-drives when it was runnin slow!
| Sun Jul 10, 2016 10:49 pm |
brycecheramie
| Sun Jul 10, 2016 11:11 pm |
