It is currently Mon Apr 06, 2026 10:38 am
Reply to topic  [ 14 posts ]
 Info on Cam for a 25 hp Kohler
Post Info on Cam for a 25 hp Kohler
I Gota 25hp efi Kohler on a Prodrive been trying to look for a cam for it anyone out there ran one in there's or a older 25-27 Kohler ?
Fri Aug 05, 2016 10:00 pm
Post Re: Info on Cam for a 25 hp Kohler
Cb will be along. He put a lot of effort into making those run. Don't think it went to well. Check with Midwest super cub.
Fri Aug 05, 2016 10:14 pm
I just put a MSC 4k cam in one. Goin to test this weekend
Fri Aug 05, 2016 10:18 pm
Yours efi ? Let me know how it goes.
Sat Aug 06, 2016 1:44 pm
Ran it today . Not an efi, its an oldie with a few thousand hours, cleaned up heads .030 deck and header .Very stong bottom end then it leans out into the 15afr range Above 3/4 throttle. bumped the main jet today and will check it again tomorro.
Sat Aug 06, 2016 9:59 pm
I finally got the top end dialed in today. Wound up have to downsize air bleed to main jet to get fuel to respond. Runs very good but seems only a little stronger if any than my last more simple combo of .005 heads ported with +3 timing abit more main jet and a header. Im sure if this one had a better intake and carb it would appreciate the cam more. Imo the cam would not be worth it unless u had a real carb. If yours is an efi i think a big cam will through your tune out of whack. I dont know if anyone has even modded one of those yet. If your that kind of guy you might be the first :D soo im still wainting to hear what CBs badass combo was
Sun Aug 07, 2016 9:33 pm
Seems like your getting it figured out .Yea don't see much on my motor guess pretty new . Gonna fuel tuner I'm putting on it tomorrow and head work is coming next .tuner should help me dial it in when I get heads done and eventually cam . Just been trying to research on the cams alittle be little while before I try out different cams
Sun Aug 07, 2016 10:17 pm
With not many exhaust options , I've made a bps q work on mine thinking bout gutting the old stock muffler don't know if that would do much besides just be louder . What you got running on your motor ?
Sun Aug 07, 2016 10:21 pm
The 2 im talkin about have custom 2/1 headers . You should start a fresh topic on your build . It being a 25 efi it goin to get alot of attention
Sun Aug 07, 2016 10:36 pm
I didn't have anything badass. I wasted a bunch of time and money when i should have just started with a bigger block.
Mon Aug 08, 2016 9:09 am
What y'all you end up doing to yours ?
Mon Aug 08, 2016 9:18 am
Put it on a shelf and replaced it with a big block. Same thing you should do.
Mon Aug 08, 2016 9:24 am
Probly rite lol just Gota mess around with it don't really want a lot of speed looking to get it push load better on boat I have a moment like the small boat and small block for what I do with it
Mon Aug 08, 2016 9:37 am
Mon Aug 08, 2016 9:45 am
