It is currently Fri Apr 03, 2026 2:14 am
Reply to topic  [ 5 posts ]
 Advancing Cam Timing question.
Post Advancing Cam Timing question.
I have seen the pics on the cam installation process where you line up the marks on the cam and the crank shaft. That part is simple. However, if I wanted to advance the timing let's say 3 degrees, what exactly is involved? Also, what would be the benefit?
My motor set up right now is .030 heads ported and polished with oversized valves, mikuni carb and Q exhaust. Boat is a 18x44 Gator Trax with 2 gun boxes and one large bench type box. Motor turns 4400 rpms with just me. I'm leaning towards the PVT cam since I looking for more top end power.
18x44 Gator Trax, Stage 2 Mudbuddy
Wed Aug 17, 2016 6:38 am
Post Re: Advancing Cam Timing question.
That has to be ground into the cam centerlines, Unless you have a Billet cam with an adjustable timing gear.
Wed Aug 17, 2016 6:58 am
is the PVT billet? If so so does it Hans an ajustible timing gear?
Wed Aug 17, 2016 7:57 am
Wed Aug 17, 2016 8:02 am
Ok thanks.
Appreciate the help
Wed Aug 17, 2016 8:35 am
