It is currently Wed Apr 08, 2026 12:58 pm
[ 5 posts ] |
Advancing Cam Timing question.
Gros'bec
Joined: Sat Jul 23, 2011 11:36 am Posts: 235 Location: Louisiana
I have seen the pics on the cam installation process where you line up the marks on the cam and the crank shaft. That part is simple. However, if I wanted to advance the timing let's say 3 degrees, what exactly is involved? Also, what would be the benefit?
My motor set up right now is .030 heads ported and polished with oversized valves, mikuni carb and Q exhaust. Boat is a 18x44 Gator Trax with 2 gun boxes and one large bench type box. Motor turns 4400 rpms with just me. I'm leaning towards the PVT cam since I looking for more top end power.
_________________ 18x44 Gator Trax, Stage 2 Mudbuddy
| Wed Aug 17, 2016 6:38 am |
MaXXis85
 Re: Advancing Cam Timing question.
That has to be ground into the cam centerlines, Unless you have a Billet cam with an adjustable timing gear.
| Wed Aug 17, 2016 6:58 am |
Gros'bec
is the PVT billet? If so so does it Hans an ajustible timing gear?
| Wed Aug 17, 2016 7:57 am |
flint87
| Wed Aug 17, 2016 8:02 am |
Gros'bec
Ok thanks. Appreciate the help
| Wed Aug 17, 2016 8:35 am |
[ 5 posts ] |
