Duck-killa
Joined: Sun Apr 08, 2012 10:48 pm Posts: 154 Location: Cut Off, LA
 Flywheel messing with carb
So awhile back I changed my stator and after a little while something happend behind the flywheel and cut my wires. Well my engine was running fine before I decided to take the flywheel back off to fix the stator problem, so I did what I had to do and fixed the wires and whatnot, and I put the flywheel on just like before, gapped my coils with a business card and now I wouldn't start back up. Blowing smoke out the carb and jerking the flywheel when it goes to crank. So I thought it was something with the carb and my minkui carb was coming in anyway so I just took it off, and I installed my minkui today and same thing. Jerking the flywheel, blowing smoke out the carb, running very rough and only for about 15 seconds then dying, really confused here
_________________ Delta lvl 3 GTR with MAC 16x54 Gator hull
| Tue Jan 10, 2017 5:41 pm |
flint87
 Re: Flywheel messing with carb
Really confused here too....
| Tue Jan 10, 2017 5:46 pm |
Duck-killa
Maybe timing is off on the flywheel somehow
| Tue Jan 10, 2017 5:53 pm |
Will C
Yes^
| Tue Jan 10, 2017 8:08 pm |
banded-mallard
Right, check your keyway. If you have a timing key, may be broken. Your flywheel isn't line up correctly.
| Wed Jan 11, 2017 5:21 am |
brycecheramie
| Wed Jan 11, 2017 5:31 am |
MaXXis85
Your timing key has probably sheared.
| Wed Jan 11, 2017 7:22 am |
Duck-killa
That's what happen, key sheared. Guess I didn't torque it enough, will torque to Briggs specs.
| Wed Jan 11, 2017 9:13 pm |
CypressCritter
Joined: Tue Aug 26, 2014 10:36 am Posts: 822 Location: Jefferson TX
Time to get an advanced timing key!! JS 300-500 rpms on the top end.
_________________ SEAARK FX 2472 CC Merc 150HP 4Stroke(CypressCadillac) Uncle J Custom - 19x54 CC Skiff w/40XD GTR
| Thu Jan 12, 2017 9:42 am |
MaXXis85
Its around 150 Foot pounds. I have a cheat sheet I keep in the shop.
| Thu Jan 12, 2017 10:14 am |
Duck-killa
I don't need any more rpms on this thing 4700 rpms is plenty enough for me lol
| Thu Jan 12, 2017 11:18 am |
CypressCritter
Get a bigger Prop or go up in pitch!
| Thu Jan 12, 2017 11:21 am |
nuccifish06
Joined: Tue Sep 16, 2014 6:36 pm Posts: 108 Location: Sunrise, FL
_________________ 1438 Jon / 23hp MBLT
| Thu Jan 12, 2017 1:20 pm |
Duck-killa
Well my GT 2 blade is still in pretty good condition but before next season, I'm gonna pick up the delta mercury 3 blade, might leave it how it is or get an extra cup in it
| Thu Jan 12, 2017 9:48 pm |
