It is currently Wed Apr 08, 2026 6:02 pm
Reply to topic  [ 14 posts ]
 Flywheel messing with carb
Post Flywheel messing with carb
So awhile back I changed my stator and after a little while something happend behind the flywheel and cut my wires. Well my engine was running fine before I decided to take the flywheel back off to fix the stator problem, so I did what I had to do and fixed the wires and whatnot, and I put the flywheel on just like before, gapped my coils with a business card and now I wouldn't start back up. Blowing smoke out the carb and jerking the flywheel when it goes to crank. So I thought it was something with the carb and my minkui carb was coming in anyway so I just took it off, and I installed my minkui today and same thing. Jerking the flywheel, blowing smoke out the carb, running very rough and only for about 15 seconds then dying, really confused here
Delta lvl 3 GTR with MAC
16x54 Gator hull
Tue Jan 10, 2017 5:41 pm
Post Re: Flywheel messing with carb
Really confused here too....
Tue Jan 10, 2017 5:46 pm
Maybe timing is off on the flywheel somehow
16x54 Gator hull
Tue Jan 10, 2017 5:53 pm
Yes^
Tue Jan 10, 2017 8:08 pm
Right, check your keyway. If you have a timing key, may be broken. Your flywheel isn't line up correctly.
Wed Jan 11, 2017 5:21 am
Wed Jan 11, 2017 5:31 am
Your timing key has probably sheared.
Wed Jan 11, 2017 7:22 am
That's what happen, key sheared. Guess I didn't torque it enough, will torque to Briggs specs.
16x54 Gator hull
Wed Jan 11, 2017 9:13 pm
Time to get an advanced timing key!! JS 300-500 rpms on the top end.
Thu Jan 12, 2017 9:42 am
Its around 150 Foot pounds. I have a cheat sheet I keep in the shop.
Thu Jan 12, 2017 10:14 am
I don't need any more rpms on this thing 4700 rpms is plenty enough for me lol
16x54 Gator hull
Thu Jan 12, 2017 11:18 am
Get a bigger Prop or go up in pitch! 8-)
Thu Jan 12, 2017 11:21 am
1438 Jon / 23hp MBLT
Thu Jan 12, 2017 1:20 pm
Well my GT 2 blade is still in pretty good condition but before next season, I'm gonna pick up the delta mercury 3 blade, might leave it how it is or get an extra cup in it
16x54 Gator hull
Thu Jan 12, 2017 9:48 pm
