It is currently Thu Apr 02, 2026 3:02 pm
Reply to topic  [ 7 posts ]
 PD question
Post PD question
Just thinking out loud here, but has anyone run their PDs without the Velcro band around the clutch? I'm asking as from what I understand the majority of failures is due to heat build up in the top bearing or coil.
Thanks all, and the snow finally melted here. Only January so more is in future ha ha
Wed Jan 18, 2017 5:50 pm
Post Re: PD question
Its not going to hold in heat to get that bearing hotter than with it off. Its there to keep water and mud from hitting the clutch
I gave up mud motors
Wed Jan 18, 2017 5:58 pm
Hey Grunt, I haven't run mine with that sucka in a while! The bearing heat comes from slippage, tighten the piss outta that crank bolt and throw that grease catcher away...
PRODRIVE 1860 CC
"Let the good times roll"
Wed Jan 18, 2017 7:51 pm
Use an impact on the clutch bolt... Dugga dugga..USe Loctite on the bolt.
Thu Jan 19, 2017 7:51 am
Thu Jan 19, 2017 5:46 pm
Fri Jan 20, 2017 4:31 pm
Ask me how I know that?!?! HAHAHA :oops:
PRODRIVE 1860 CC
Fri Jan 20, 2017 6:57 pm
