It is currently Wed Apr 01, 2026 6:06 am
Reply to topic  [ 52 posts ]  Go to page 1, 2  Next
 Any one working on the 37 EFI performance parts yet?
Post Any one working on the 37 EFI performance parts yet?
I'm wondering if anyones started working on the new EFI from briggs? working on programmer? or have you added other parts and the stock tune accepted it?
Mon Mar 02, 2015 9:12 am
Post Re: Any one working on the 37 EFI performance parts yet?
There are a few other threads on this already. Please go read those instead of starting this up in another one.
Mon Mar 02, 2015 9:46 am
40HP Gatortail
Mon Mar 02, 2015 9:58 am
Mon Mar 02, 2015 10:08 am
Do the mods you want, install a WEGO wideband sensor or similar in the exhaust, increase fuel pressure until you achieve your preferred AFR at full load.
Mon Mar 02, 2015 10:16 am
Mon Mar 02, 2015 11:02 am
how are you going to increase fuel pressure without any way to hook it to a computer? i know thats what i need to do but idont know how?
Mon Mar 02, 2015 11:09 am
Mon Mar 02, 2015 11:16 am
Mon Mar 02, 2015 11:18 am
its not injected into the block its misted into the intake
Mon Mar 02, 2015 11:41 am
yes - ML, B/S EFI should be close to this, I think. I hope it's not injecting fuel into the block. I think what he means by engine is combustion chamber
Mon Mar 02, 2015 11:55 am
i like that WEGO setup -
Mon Mar 02, 2015 12:00 pm
Tue Mar 03, 2015 12:16 am
Tue Mar 03, 2015 7:59 am
Tue Mar 03, 2015 8:29 am
Tue Mar 03, 2015 8:58 am
I agree with leaving them stock. I just see so many people asking about modding the EFi engines, and I feel that an aftermarket ECM or someone going through the work to build a software system to tune the stock ECM is a long ways off. It's something the MM industry has not dealt with. It's a huge investment upfront to develop that technology.
Tue Mar 03, 2015 9:25 am
Tue Mar 03, 2015 9:28 am
1844 GD with 35HP GDSD
Tue Mar 03, 2015 9:31 am
Tue Mar 03, 2015 12:56 pm
As long as it's just heads and exhaust I would think that increasing the pressure would work just fine. You aren't changing the curve at which the engine creates power, just raising it I would think. As long as nobody goes to a radical cam design or a very high compression I would t think it would be an issue as long as you could get your mixture right.
Tue Mar 03, 2015 1:25 pm
Tue Mar 03, 2015 1:49 pm
Tue Mar 03, 2015 2:10 pm
My buddy who just ordered a 37EFI on a GT 1748, and who isn't tech-savvy and still has a flip-phone, mentioned he might put an aftermarket exhaust on his 37EFI.
Any [real] benefit to increased exhaust flow with the stock mapping, other than getting his eardrums blown out?
Tue Mar 03, 2015 3:52 pm
No real benefit to an aftermarket exhaust without anything else done no matter how the fuel gets in the heads..
Tue Mar 03, 2015 4:00 pm
Tue Mar 03, 2015 5:39 pm
Tue Mar 03, 2015 6:04 pm
Tue Mar 03, 2015 7:16 pm
His witty retort was "then how does a turbo-back exhaust allow better performance on a diesel truck without a tuner" and I said "How the hell should I know, I'm not a Duramax mechanic"
Maybe he's just itching for a loud motor.
Discuss.
Tue Mar 03, 2015 10:03 pm
On a big hp motor, you might pick up a few hp, which may be noticeable. On a lawnmower engine, you may pick up .00001hp which is not likely to be noticeable.
Tue Mar 03, 2015 10:05 pm
I can't crush his hopes and dreams with that response, CB. Even I know that everything is relative when we're talking HP to weight ratio. The small hp increase he sees on his Duramax is being applied to an 8000lb truck not a 500lb boat.
Give me something better than that to make his head explode.
Tue Mar 03, 2015 10:08 pm
Tue Mar 03, 2015 10:32 pm
37 PD EFI FPR 18x48 Tiller
SOLD -- 27 PD FPR 16x36 Skiff
Tue Mar 03, 2015 11:24 pm
Wed Mar 04, 2015 6:02 am
LM2's suck..... I've had three different setups from Innovate and sent every one back. Not just sensor problems either... I had an LC1 in my personal truck (turbocharged LS setup) and it was slightly better, but still was very glitchy ended up swapping it to the NGK setup after burning a head and piston up pretty bad. I didn't have a real "ragged edge" type setup either. 780rwhp 347ci iron block with good heads and a Precision 78mm turbo, all in an 02 Ext cab Silverado. It ran pretty good though ;)
I have tuned 1000rwhp setups with this one and it's always been right on the money with the portable setup at the dyno (usually an LM2) it's less expensive and it holds up better. I installed one in a mud truck that belongs to a friend and it gets pelted with mud and pressure washer weekly and keeps going... The display is easy to glance at and read on the fly too.
http://www.ngksparkplugs.com/products/p ... ce/afx.asp
Wed Mar 04, 2015 6:21 am
Thu Mar 05, 2015 9:38 am
Thu Mar 05, 2015 10:03 am
Thu Mar 05, 2015 10:07 am
Tiny tach makes the connector cable from the engine's diagnostics plug to the laptop(usb).
The part that scars me is if folk who don't know how to tune, get there hands on some software that can eventually reprogram the ecm, you will see a lot of failures.
Thu Mar 05, 2015 10:11 am
Thu Mar 05, 2015 10:13 am
