It is currently Sun Apr 05, 2026 11:08 pm
Reply to topic  [ 46 posts ]  Go to page 1, 2  Next
 Whose gonna go with a lectron?
Post Whose gonna go with a lectron?
Saw on deltas Facebook page they started using the lectron carbs. I don't know much about them. Seem easier to tune. I know that delta performance produce quality parts and service.
Anyone have any info on the carbs themselves?
Thu Sep 01, 2016 11:11 am
Post Re: Whose gonna go with a lectron?
If Jamie and Calen like it, I'm sure there's good reason. I wouldn't worry too much about it. There's tons of carbs that will work fine on these motors, getting the intake adapters and stuff like that is the hard part.
Thu Sep 01, 2016 11:23 am
Sounds like a good way to come up with a kit and mark it up then sell it to everybody you already sold a Mikuni kit to and now even people you haven't . Latest and the greatest .
Thu Sep 01, 2016 12:01 pm
Looking 5 years into the future of MMT:
" I know a few guys still running the old Mikuni setups and dont have any problems with them"
Thu Sep 01, 2016 12:04 pm
Probably the same people who change exhausts everytime somebody comes up with a new looking one......if I had to guess.
Sent from my SAMSUNG-SGH-I537 using Tapatalk
Thu Sep 01, 2016 12:26 pm
Thu Sep 01, 2016 12:34 pm
^^^ drinker of the cool aid ^^^^
Thu Sep 01, 2016 1:28 pm
Far from it man. I won't be buying any of it (they don't have parts for my motor even if I wanted to). Just saying, them two boys know they're shit so I'm sure whatever they chose is a good option. Again, my best guess is that this has more to do with setting themselves apart a bit, more than anything else. I doubt it's much of a performance difference. I would also suspect that THEY believe it's a better option for some reason or another.
Thu Sep 01, 2016 1:32 pm
Looks similar to the PSI big air.
Thu Sep 01, 2016 1:52 pm
Im sure they've dyno'd the both of them and on paper theres most likely a performance improvement. Whether or not the numbers on the dyno sheet is enough for the user to notice a difference between a mikuni and a lectron is another story.
Thu Sep 01, 2016 1:53 pm
Thu Sep 01, 2016 2:04 pm
^ :lol:
Thu Sep 01, 2016 2:05 pm
Follow the money trail....
Prolly get the Lectron's cheaper and get same performance as Mikuni....and charge end users the same $$.
Thu Sep 01, 2016 2:39 pm
The lectron carbs been around awhile. There used alot in in the motocross world n are big power makers in that type of use plus there easy to tune. But on the other hand there expensive n probably overkill for a mudmotor unless ur trying to make 60 hp with ur stage 4 kits. Wink wink
Thu Sep 01, 2016 6:14 pm
Thu Sep 01, 2016 7:17 pm
Thu Sep 01, 2016 7:30 pm
Thu Sep 01, 2016 7:48 pm
So the kit from bps is like 820$ or something. So this one is 495 + 350 for the intake + whatever for the throttle cable/filter and whatever else.
Thu Sep 01, 2016 7:54 pm
I'm going to make a list of the pros and cons of the 38 MM Lectrons vs the 42 MM Mikuni. There are quite a few pros over the Mikuni. One of the things I can promise you, is the 42 Mikuni will not even come close to the Lectrons on the bottom end power and mid range power, and how smooth the engine runs. It's ran for 8 hrs a day straight with out a hiccup for the flood rescue. Some with Mikunis were having problems with engine killing and it accepting throttle when smashed to get out of the swift current. Lectrons performed flawlessly
Thu Sep 01, 2016 7:59 pm
Our carb kits are $900
Thu Sep 01, 2016 8:02 pm
Nobody is doubting the carbs. Like others said, if y'all switched there's a reason. I think the main jist is would it be worth it to replace your Mikuni.
Thu Sep 01, 2016 8:05 pm
I'm not saying that, if that's how it sounded, I apologize. I was just giving some positives on it. One of the things that we at Delta Performance like out of our engines is torque. The Lectrons definitely out torques the 42 Mikuni! As for as worth it for switching, that's going to be up to the end users. I don't like to push products on people. I will only give the advantages and disadvantages of the products we test and use.
Thu Sep 01, 2016 8:10 pm
Thu Sep 01, 2016 8:29 pm
Mikuni's are cheaply built, and a pain to tune.
Lectron has been around a long time I used them on my drag bike years ago and they were the easiest carb I have tuned.
I can say that the prices Delta are selling these for compared to the Mikuni carb and kits it's worth the extra money you won't regret it.
You look into the race world of carbs and Mikuni isn't even on the list ,why bc they are harder to tune for each track application and not consistent. Going from pilot jet sizes to needle jets, slide cut always and so on who has time for that when you want the engine running at its best.
If you want more power and reliability / less fuel consumption for those long runs to the duck blind or fishing hole, it's simple trash the Mikuni and get a Lectron
Thu Sep 01, 2016 9:27 pm
Hey, y'all buy whichever carb you want, but PLEASE don't vote for Hillary.
37 PD EFI FPR 18x48 Tiller
SOLD -- 27 PD FPR 16x36 Skiff
Thu Sep 01, 2016 10:01 pm
/\this
1854 Prodigy DPE Level 3 HDR
Fri Sep 02, 2016 3:50 am
The mikuni carb is fine and they make power but I see what delta is trying to do with the lectron. The mikuni 42HSR has been the staple for a while now but its a little big for the power were making with these engines and sometimes produces a weak signal depending on the intake and flow of the heads causing the user to have to jet up higher than normal. I haven't run the lectron but it seems like a good idea to try one due to the carb bore being tapered and the metering rod location creating velocity and helping the engine pick up/atomize the fuel charge better than a mikuni. I'm sure some of you will get what I saying and some will argue but these carbs seem better than a mikuni from what ive read.
having said all that im still gonna stay with my mikuni for a while cause its too close to duck season to start dumping money in my motor again.
Fri Sep 02, 2016 6:11 am
^^^^. This , I have been reading up on them. , jet less. , NOJETS , I'm looking at the. 32-34 mm about 3-400$ range new from lectron. To try on this small block. I currently am running a 34 round slide mikuni. Re jetted pilot and main , huge main jet. , that I fight a rich condition all the time. , this may be just the ticket for me. Looks to be a much better carb on paper.
H Finn
GATOR GLIDE PROSTAFF
BACKWATER PROSTAFF
http://www.gatorglide.com
Coupe rest in peace brother
Fri Sep 02, 2016 6:41 am
Will these mount up to PVT adapters?
1438 Jon / 23hp MBLT
Fri Sep 02, 2016 7:53 am
I will be going with one. I am on the list.
For the naysayers or doubters, just be patient like those who are waiting in line to get one. Once the reviews come out we will see where things fall in line.
With some of this "KIT", we aren't comparing apples to apples. The DPE Intake Adapter is a highly customized piece and not comparable to other intake adapters whatever you are running. Delta also promises no necessary rework or fitting. The adapter is ready, and if you look on their Facebook page, yea, the price might seem high, but you get what you pay for.
If you already have a Mikuni, I would think you have all the necessary parts to switch carbs only. I don't know what performance would be like, but I 'm sure Calen and Jaimie would work with anybody on this, and then you could turn around and sell the Mikuni. Or not.
Let's wait and see how these things work out. They have plenty enough people willing to be the guinea pig on this and I am one of them. :lol:
I also think some of our community understands what Delta is doing and has going for them, and some of the community; I can see its just over their head.
I gotta get me one
Fri Sep 02, 2016 8:25 am
Didn't people once complain of limited options. I don't even have a carb motor and think that DPE offering something new with actual run data is great. Competition breeds improvement.
Fri Sep 02, 2016 8:42 am
We're gonna complain no matter what! Too much, too cheap, not enough options, too many decisions! :lol:
Fri Sep 02, 2016 9:10 am
Fri Sep 02, 2016 9:17 am
If the kits are $900, would you be able to buy just the carb if you already have the intake adapter for a cheaper price?
Fri Sep 02, 2016 9:23 am
I'm all about improving and innovating beyond what the accepted norm has been....I probably could have saved a lot of money, time and headache to go with the accepted norms...but, through that process of innovation, trial and lots of error....I am where I am with my motor...and the restrictions I have to contend with where I hunt.
Fri Sep 02, 2016 9:31 am
HOTSAUCE170 wrote:
Fri Sep 02, 2016 9:40 am
Fri Sep 02, 2016 9:47 am
Yes you will be able to buy the carb by itself. The Lectrons with fit in any intake adapter that is offered now with a carb boot change. We are working on 2 different size plenum adapters for our intakes. The reason behind this is for the existing 42 MM carbs and also for the new 38 MM Lectrons. The plenum for the 38 MM will be tapered down in the ID of the adapter for streamline flow. The adapters that we have released on the market already are fit for the 42 MM streamline. The plus about our intake design is that with just the plenum change it will fit both
Fri Sep 02, 2016 9:48 am
Fri Sep 02, 2016 3:37 pm
