It is currently Fri Jul 11, 2025 10:30 pm
Reply to topic  [ 125 posts ]  Go to page Previous  1, 2, 3, 4  Next
 The first MB with reverse- yep I did it
Post The first MB with reverse- yep I did it
Gonna be really cool when you pull on the side of other mb and take off lol!! Only thing I'm not to sure of I know when you turn the mb frame all the way to the side it rolls on it's side !! Trying to reverse with with jumping is gonna be a little hard but I guess it's better than push polling !!
17x48 extreme stage 2 GTR
Thu Feb 16, 2012 6:47 am
ANYTHING is better than a push pole!!!! When I first saw the gears for sale, the wheels started turning in my head, trying to figure out how to do it. Once you figure out how far to space the belt housing for pulley alignment and a way to mount the caliper it's a piece of cake. Originally I wasn't gonna have to chop the top of the housing off, but the clutch was so close to the upper inside wall that I was afraid of it hitting if I re geared and had to apply more belt tension. It uses the same brake lever for operation too. I still have to clean up a few cuts, then build a nice cover for it all, and I'll be backing it on up!!!!
Thu Feb 16, 2012 8:34 am
Post Re: The first MB with reverse- yep I did it
Cant wait to see it in action....i hope some video gets posted soon!
Should be fun to watch when the MB starts pulling instead of pushing!!!
Thu Feb 16, 2012 9:02 am
This will definitely leave some with a bit of jealousy.
Thu Feb 16, 2012 9:10 am
Excellent!
At least you won't have to worry about the clutch cover melting. :lol:
Thu Feb 16, 2012 9:19 am
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Thu Feb 16, 2012 9:27 am
Don't hate!! Lol
Thu Feb 16, 2012 9:43 am
Thu Feb 16, 2012 10:08 am
I was thinking the same thing about this reverse gear when I saw it for sale. You the man that turned a vision into reality. So its a mudtail or Gatorbuddy?
Thu Feb 16, 2012 10:28 am
Profile YIM
Brooks parts department is just fine!!
he's not the first one to do it. :roll: seen that done two yrs ago a guy and i think his buddy also did it they were from minn. hope they are on this site and respond. i guess if all u dumb forkers that own a mudbuddy might want to do this. than gt can charge a 2000.00 return core charge. the rich get richer and the ones that want reverse get poorer.
Thu Feb 16, 2012 7:50 pm
all i can say is that i called this a while back......good job
Thu Feb 16, 2012 7:54 pm
Thu Feb 16, 2012 8:03 pm
SCmudder7071. at the time i saw it and when is see it now being done. i could care less. as far as the $2000.00 core charge i'll taaaalk a littttte slowwwwwer forrrr youuuu. theee corrrrre chargeeee woulddd beee forrrr thhhhe reverssse uunitttt notttt theee blockkkk dumbbb azzzz. twooo weeeek waiiiit onnnnn partttts.
Thu Feb 16, 2012 8:37 pm
Rod, you are definitely a smart dude with the tools and skills to turn heads, stir some comments from some and shut others up!
I hope this works great and you have her put together before next weekend. ;)
Thu Feb 16, 2012 10:01 pm
Thu Feb 16, 2012 10:24 pm
Thu Feb 16, 2012 10:27 pm
Thanks Clay, that was a lot easier to rrreeeaaaaaddddd! :lol:
Thu Feb 16, 2012 10:35 pm
Thank you sir :D
Thu Feb 16, 2012 10:52 pm
Fri Feb 17, 2012 6:23 am
How many times you think this was done out west will trying to figure how to some how copy it
Fri Feb 17, 2012 6:30 am
Fri Feb 17, 2012 6:48 am
Rod, Now you can enjoy having a nice feature for your motor. I seen the pic on FB and seen how you did it.. I like it. I suggest one thing.... Make yourself a different belt housing cover where you had to cut the casting out to bolt the Caliper. It works now, But for Better asthetics.... you get my drift.
Rod is a tinkering feller. I knew onew day someone would do it. GT reverese is simple,reliable, and bolts to a briggs motor...Props to the man has built 2 mudmotors for way under retail value.
Fri Feb 17, 2012 6:59 am
Yeah I am gonna replace that part Marcus, didn't have anyone thick plate. Also, the clutch cover will hide that.
Fri Feb 17, 2012 8:42 am
Maybe add some flames drawn into the clutch cover, and MBR. Not cut all the way through though.
Fri Feb 17, 2012 8:45 am
Fri Feb 17, 2012 8:53 am
How many times have you been on the water with it to test it out
Fri Feb 17, 2012 8:59 am
Haven't ran it yet, boats not finished. Should be ready this weekend.
Fri Feb 17, 2012 9:14 am
Sounds to me like yall need to get here Thursday instead of Friday
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Fri Feb 17, 2012 9:35 am
I wish I could!!
Fri Feb 17, 2012 9:36 am
You do know according to the double douche duo the as much problem's their is with gt parts that your only gonna get one use out if it!! Then parts are gonna be hard to find lol
Fri Feb 17, 2012 10:17 am
Are you gonna run a mb prop?
Fri Feb 17, 2012 10:22 am
Fri Feb 17, 2012 10:46 am
Fri Feb 17, 2012 10:47 am
It would be so easy for Gator Tail to design a mechanical link between the reverse lever and the clutch switch so that all one would have to do to engage reverse is press the lever. The action would have to have a built in fail-safe feature to avoid disengagement of the clutch at high rpms. More better instant reverse.
Fri Feb 17, 2012 12:26 pm
wrong thread
Fri Feb 17, 2012 12:30 pm
Fri Feb 17, 2012 1:02 pm
:lol:
Fri Feb 17, 2012 1:05 pm
Fri Feb 17, 2012 2:05 pm
Good Job Rod. Make sure ya got your flotation device and life jackets this time at SETX! :lol:
Fri Feb 17, 2012 3:33 pm
Users browsing this forum: No registered users and 100 guests
