It is currently Sat Jun 28, 2025 12:30 am
Reply to topic  [ 20 posts ]
 Valve adjustment question
Post Valve adjustment question
I've got a 35 GDSD with about 200 hours on her. To my knowledge, the valves have never need adjusted. I'm trying go find out if the 35 vanguard had adjustable valves or do I need shims to adjust them? I've noticed that lately it's been a little harder to start my motor and a little bit of black smoke out of the exhaust when I do start it up. It usually gets worse once the motor is hot after running for a while.
Am I correct in thinking that a valve adjustment would help use issues?
Sun Jul 04, 2010 7:01 pm
Post Re: Valve adjustment question
Pull your valve covers off and set dem at 0.005 while at a 1/4" past top dead center.
Sun Jul 04, 2010 7:20 pm
Thanks. I'll probably get that done this week.
Sun Jul 04, 2010 8:52 pm
Its real easy to do...just go get you a feeler gauge and set em to .005
Sun Jul 04, 2010 9:02 pm
Sun Jul 04, 2010 9:16 pm
Profile YIM
Chris and I are gonna do it one day this week.
Sun Jul 04, 2010 9:34 pm
ya thought so but do me a fav and see if he would do mine for me to
Mon Jul 05, 2010 3:18 am
Profile YIM
When exhaust is open... Set intake
When Intake is open... Set exhaust
Repeat for the second hole
Mon Jul 05, 2010 2:29 pm
You guys are so smart. I wish I could be like yall. Your all my idols.
BUCK OFAMA
Mon Jul 05, 2010 4:44 pm
compression stroke................
Don't mistake my kindness for weakness, my ability to look over things as ignorance - but make no mistake, when I've had enough, I'm Coming After you. Watch Your Back....lol
Mon Jul 05, 2010 5:14 pm
Well, adjusted my valves this afternoon. Really easy job. But I did find a new problem while doing so. Went ahead and checked compression and I'm WAY low on each cylinder. 82 on one side, 86 on the other. I really could have done without this. Oh well, time to start looking for parts.
Mon Jul 05, 2010 6:11 pm
BUCK OFAMA
Mon Jul 05, 2010 7:08 pm
No, didn't open the throttle. Guess I'll have to check it again.
Mon Jul 05, 2010 7:46 pm
Mon Jul 05, 2010 8:16 pm
Mon Jul 05, 2010 8:17 pm
BUCK OFAMA
Mon Jul 05, 2010 8:24 pm
Without the throttle open the intake is basicly a closed valve cutting off your air supply. No air means your not going to get the air needed to displace / fill the cylinder, causing the piston to draw some what of a vaccum until it can compress what air that it had or what it could actually suck in.
Is that right BJG? :mrgreen:
Mon Jul 05, 2010 8:25 pm
BUCK OFAMA
Mon Jul 05, 2010 8:28 pm
either that or u set the valves to loose. But i dont think thats the case. They would have to be really loose.
BUCK OFAMA
Mon Jul 05, 2010 8:31 pm
one day I"m gonna grow up big just like you smart fellas.......You guy's rule .....lol thanks for the explanation. Learned something new everyday.
Mon Jul 05, 2010 9:20 pm
Users browsing this forum: No registered users and 116 guests
