It is currently Sat Jun 28, 2025 2:12 pm
Reply to topic  [ 28 posts ]
 Motor shutting off?
Post Motor shutting off?
Today i left my pod-nuhs house in my boat and about 2min after i left my motor just shut off. I checked my kill switch an it was fine, then I checked my plugs an they looked fine an were getting fire. Maybe this could be an elecrtical issue? Anyone ever experienced a problem like this?
36hp Pro-Drive with EVT exhaust pushin a 17x42 custom skiff
Wed Jul 21, 2010 9:27 pm
Post Re: Motor shutting off?
Low oil?
1644 Go-Devil
2008 23 GDSD
Wed Jul 21, 2010 9:34 pm
Wed Jul 21, 2010 9:39 pm
Assumed you checked all the wires at the back of the switch. If the Tach is registering RPM, then its getting fire on the plugs. If not, things to check are kill switch, oil pressure sensor (if installed). On stock carb, the anti-backfire solenoid on the fuel bowl must be open for it to get fuel (you hear a click when you turn the key).
I had an aftermarket PWC kill switch key that looked the same size as the one that came with my motor, it was just a hair too big and would kill it after 2 min of idle and at odd times.
Thu Jul 22, 2010 5:46 am
If that's the same motor I seen you with, it requires Fuel. Low fuel could surely cause your problem.
Thu Jul 22, 2010 5:54 am
My 23GDSD did that. It was the kill switch. Changed it and never had a issue again.
Ideas not coupled with action
never become bigger than the
brain cells they occupied.
Owner
Thu Jul 22, 2010 6:56 am
Head space and timing in operator.
Thu Jul 22, 2010 9:11 am
Thu Jul 22, 2010 9:28 am
Switch but mine was only 3 months old at the time. Yours has some age on it sooooo....
Owner
Thu Jul 22, 2010 9:55 am
Thu Jul 22, 2010 9:59 am
Well no luck! I went bought a new kill switch an checked my oil level an its good! Tried startind it for like 5min but still wont start. Any other ideas what could have caused this problem?
Thu Jul 22, 2010 11:25 am
Is it for sure gettin both fire and fuel? I had a problem with a bad connection with some of the ignition wires.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Thu Jul 22, 2010 11:29 am
Thu Jul 22, 2010 11:35 am
Then just by pass the kill switch and confirm it...
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Thu Jul 22, 2010 11:47 am
Thu Jul 22, 2010 11:57 am
Thu Jul 22, 2010 11:58 am
MMT Moderator
GTB 1860 w/ 2019 GTR40XD-HO
Thu Jul 22, 2010 12:44 pm
Thu Jul 22, 2010 1:08 pm
Sometimes it's best to just keep your fingers quiet...
Thu Jul 22, 2010 1:20 pm
Checked your fuel shut off valve on the bottom of the carb?
Thu Jul 22, 2010 2:13 pm
Someone correct me please ........ ifin' it was indeed in the killswitch .... wouldn't that kill the fire in the wires ????
Thu Jul 22, 2010 2:32 pm
:oops: Sho nuff, don't know what I was thinkin. lol We need that smilie hittin himself in the head. :lol:
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Thu Jul 22, 2010 2:51 pm
I figured out the problem! I got ahold to some bad gas, or either the new gas hose i put in my boat had something in the inside of it! I have one of those clear inline gas filters an the was an orange color! I drained the gas out the filter then put it back on an it took me about 2min to get it going then once i got it to burn the gas out the carb an now it runs like a top! Anyone ever had this problem???
Thu Jul 22, 2010 7:14 pm
Yeah I've had bad gas before.
It ussually happens after I eat pickled quail eggs and chocolate milk.
Thu Jul 22, 2010 7:17 pm
18x48 Charles Leonard / 36PD
Thu Jul 22, 2010 7:20 pm
Owner
Thu Jul 22, 2010 7:21 pm
May have had some Bee Pee in it. That will give it an orange color. :lol:
Thu Jul 22, 2010 11:06 pm
Users browsing this forum: No registered users and 183 guests
