It is currently Sat Jun 28, 2025 9:37 am
Reply to topic  [ 16 posts ]
 Spec sheet for a EVT Cam
Post Spec sheet for a EVT Cam
Looking at buying Brinkleydogs EVT cam instead of taking mine out and sending it off to be worked on. My motor guy is asking for the spec sheet so he can see if it will work with what he's doing. Anyone know if there is a spec sheet out there on it? Their website is not working.
Thu Jul 22, 2010 12:33 pm
Post Re: Spec sheet for a EVT Cam
I'm sure there is one but I doubt anyone is gonna give up the info.
Thu Jul 22, 2010 12:57 pm
Thu Jul 22, 2010 1:12 pm
I had asked that question a long time ago and got ro reply. Dude you are not going to get anyone to give you cam specs. Forget it.
Thu Jul 22, 2010 3:22 pm
Maybe you could get the little guy from out west to get it for ya... :lol:
Sometimes it's best to just keep your fingers quiet...
Thu Jul 22, 2010 3:28 pm
Just purchase Brinkleydogs and then have your builder determine if the profile is compatable. If it isn't throw it back up for sale.
Thu Jul 22, 2010 3:58 pm
x2. You should easily be able to get your money back out of it if for some reason it won't work with it. Only reason I could figure it wouldn't work (and correct me if I'm wrong guys) would be if your heads are decked too much. What other work is being done to your motor?
Thu Jul 22, 2010 4:02 pm
Thu Jul 22, 2010 7:21 pm
Thu Jul 22, 2010 7:43 pm
I didn't read the fine print.
"To search for Illustrated Parts Lists you MUST enter the engine's Model Type Trim number"
No wonder it was just pulling up the owners manual.
Fri Jul 23, 2010 6:34 am
The cam will work fine in your motor. We have tried different lifts and durations and this one worked the best. If your guy wants to know that bad then tell him to put a mic to it. :D
Fri Jul 23, 2010 11:43 am
Fri Jul 23, 2010 2:06 pm
wow.... doing mods to a motor and you dont know what a mic is.... i really have to ask this and i am not trying to be rude just helpful.... if you are doing mods, just be prepared to turn a wrench every once in a while... if you are not the type to do that then mods are not going to be the best option for you... these motors are fairly simple and easy to work on but most cost money upfront and continue to cost some money on engine upkeep.... especially if it is a briggs....
Fri Jul 23, 2010 3:17 pm
just get a 493 from EVT and slap in der. u'r thinkin' way too much about it!
Fri Jul 23, 2010 7:58 pm
[quote="coondik"]just get a 493 from EVT and slap in der. u'r thinkin' way too much about it![/quote]
x2!!
Fri Jul 23, 2010 8:10 pm
Sat Jul 24, 2010 10:15 pm
Users browsing this forum: No registered users and 133 guests
