TDUET
Joined: Sun Jul 04, 2010 12:57 pm Posts: 701 Location: Luling, LA (St. Charles Parish)
 New CDI motor
What kinds of mods can we do to this motor?? I hear ther is not much yet but....... I know some of yall are good like that!
_________________ GatorTail 18x54 extreme Center Console 37EFI "Ole Man Rig"
Wed Aug 18, 2010 9:30 pm |
deadbird8
 Re: New CDI motor
carb(s), heads, exhaust, cam, pistons, roller rockers, push rods, connecting rods
Wed Aug 18, 2010 9:58 pm |
TDUET
 Re: New CDI motor
So I guess my next mod will be a carb!! Lol. Any thing special I need to be or be aware of or will it take a carb just like the older 35hp?? And what carb would you go with or are u running already?
Wed Aug 18, 2010 11:01 pm |
Team Camo
Joined: Thu Oct 01, 2009 4:49 pm Posts: 8536 Location: Bridge City, TX
 Re: New CDI motor
Just call Keith and be done with it.
_________________ 1846 GTB & 35 GTR Team Gator-Tail
Killer Kallz & ANGLE PORT dealer (409) 720-8949
Wed Aug 18, 2010 11:22 pm |
MaXXis85
 Re: New CDI motor
The differences with the Newer CDI motors are the coils (built in Rev limiter), new charging stystem, and a stock stainless muffler. With that said you can do any mods you want to the engine, but you cant spin more than 4300 ish RPMs.
Thu Aug 19, 2010 6:30 am |
Old School
Joined: Thu Dec 17, 2009 9:44 pm Posts: 3067 Location: Earth
 Re: New CDI motor
So, is the rev limiter on the new csi engines a good thing?
_________________ Gator tail
Thu Aug 19, 2010 6:33 am |
JBREAUX
Joined: Tue Jan 13, 2009 8:12 pm Posts: 412 Location: soufff la
 Re: New CDI motor
So if the rev limiter is built into the coils is it possible to swap them out for the old style coils?
Thu Aug 19, 2010 6:52 am |
MaXXis85
 Re: New CDI motor
Thu Aug 19, 2010 6:57 am |
craig
Joined: Tue Jan 13, 2009 7:53 pm Posts: 7515 Location: Chauvin
 Re: New CDI motor
_________________ 1750 GatorTail Extreme/Stage 3 37 GTR HD Procrastination is a lot like masturbation. Sure it sounds great at the time but, in the end your only f--k--g yourself.
Thu Aug 19, 2010 7:12 am |
TDUET
 Re: New CDI motor
Sounds good, thanks for the help! Carb will be next!
Thu Aug 19, 2010 9:39 am |
TDUET
 Re: New CDI motor
For the time being, would replacing the stock air fliter, with and k&n help any.. I know it does some when in my cars and trucks... Just wondering. and what size k&n would that be?!
Thu Aug 19, 2010 9:50 am |
chops3131
Joined: Sun Oct 04, 2009 4:34 pm Posts: 1182 Location: Beaumont TX
 Re: New CDI motor
We have the CDI carb kits in stock Let me know if there is anything i can help you with (409)736-3999
Thu Aug 19, 2010 12:29 pm |
deadbird8
 Re: New CDI motor
K&N is E4665
Wiring harness is different between the two motors. Diodes are built in the coils on the CDI so if you swapped the coils you would need to add extensions with diodes to your ground wires. The flywheel is a different part number than the stock flywheel on the IPL but the IPL is incomplete and doesn't show the 50A stator so who knows. I got to the point of starting to loosen the CDI coils to replace but noticed the harness difference and decided to do it after the season.
Note- Built in rev limiter is much smoother than the aftermarket- just drops RPM and smoothly.
Thu Aug 19, 2010 2:23 pm |
JBREAUX
 Re: New CDI motor
Thanks, I figured it couldnt be as easy as just swapping the coils
Fri Aug 20, 2010 6:23 am |
Truckman
Joined: Mon Jun 07, 2010 10:10 am Posts: 61 Location: Moncks Corner, SC
 Re: New CDI motor
I have been wonder the same about mods on the CDI. However they don't need much in my opinion. My buddy and I have the same set up, his is and 07 PD with a Carb and BPS exhaust. He had the stock exhaust on it the other weekend and we ran the same speed with th same load, 2 people cooler. I'm thinking the exhaust will bump it up plenty. Just my .02.
_________________ 1754 ProDrive X series 36Hp ProDrive
Fri Aug 20, 2010 1:38 pm |
Chico80x
Joined: Tue Aug 11, 2009 10:55 am Posts: 743 Location: Ft. Lauderdale, FL
 Re: New CDI motor
I wonder if any company is planning on coming out with some modded coils with a 5100 rpm rev limit built in? If they did, it would probably make the older ignition system obsolete on the higher performance engines with the higher rev limits.
_________________ "We Are Products Of Our Decisions"
Fri Sep 03, 2010 10:00 am |
Lockedwings87
 Re: New CDI motor
That is correct Chico!!
Fri Sep 03, 2010 10:41 am |
deadbird8
 Re: New CDI motor
Yep
Fri Sep 03, 2010 10:54 pm |
TDUET
 Re: New CDI motor
Chops.. Im think about getting that card soon.. I was wondering about the new black death intake also.. Is this needed being I would only have muffler and carb?!?!
Tue Sep 07, 2010 1:14 pm |
Team Camo
 Re: New CDI motor
If you're gettin the carb, it'll come with the adapter for your intake, the BD intake isn't necesary, but will give added gains in performance.
Tue Sep 07, 2010 5:22 pm |
TDUET
 Re: New CDI motor
That's what I was wondering if it would help a little more bring it would be more air. But I wasn't sure if it would help being I don't have any internal work done nor do I plan to. Muffler and carb is all I plan. But if the bd intake will help I'll also think about that when buy'n the carb
Tue Sep 07, 2010 6:03 pm |
TDUET
 Re: New CDI motor
My throttle lever already cracked and broke... Anyone have any replacement tips on a better design
Fri Sep 10, 2010 3:33 pm |
