It is currently Mon Jun 30, 2025 12:48 am
Reply to topic  [ 22 posts ]
 New CDI motor
Post New CDI motor
What kinds of mods can we do to this motor?? I hear ther is not much yet but....... I know some of yall are good like that!
Wed Aug 18, 2010 9:30 pm
Post Re: New CDI motor
carb(s), heads, exhaust, cam, pistons, roller rockers, push rods, connecting rods
Wed Aug 18, 2010 9:58 pm
So I guess my next mod will be a carb!! Lol. Any thing special I need to be or be aware of or will it take a carb just like the older 35hp?? And what carb would you go with or are u running already?
Wed Aug 18, 2010 11:01 pm
Just call Keith and be done with it.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Wed Aug 18, 2010 11:22 pm
The differences with the Newer CDI motors are the coils (built in Rev limiter), new charging stystem, and a stock stainless muffler. With that said you can do any mods you want to the engine, but you cant spin more than 4300 ish RPMs.
Thu Aug 19, 2010 6:30 am
So, is the rev limiter on the new csi engines a good thing?
Gator tail
Thu Aug 19, 2010 6:33 am
So if the rev limiter is built into the coils is it possible to swap them out for the old style coils?
Thu Aug 19, 2010 6:52 am
Thu Aug 19, 2010 6:57 am
Thu Aug 19, 2010 7:12 am
Sounds good, thanks for the help! Carb will be next!
Thu Aug 19, 2010 9:39 am
For the time being, would replacing the stock air fliter, with and k&n help any.. I know it does some when in my cars and trucks... Just wondering. and what size k&n would that be?!
Thu Aug 19, 2010 9:50 am
We have the CDI carb kits in stock Let me know if there is anything i can help you with (409)736-3999
Thu Aug 19, 2010 12:29 pm
K&N is E4665
Wiring harness is different between the two motors. Diodes are built in the coils on the CDI so if you swapped the coils you would need to add extensions with diodes to your ground wires. The flywheel is a different part number than the stock flywheel on the IPL but the IPL is incomplete and doesn't show the 50A stator so who knows. I got to the point of starting to loosen the CDI coils to replace but noticed the harness difference and decided to do it after the season.
Note- Built in rev limiter is much smoother than the aftermarket- just drops RPM and smoothly.
Thu Aug 19, 2010 2:23 pm
Thanks, I figured it couldnt be as easy as just swapping the coils
Fri Aug 20, 2010 6:23 am
I have been wonder the same about mods on the CDI. However they don't need much in my opinion. My buddy and I have the same set up, his is and 07 PD with a Carb and BPS exhaust. He had the stock exhaust on it the other weekend and we ran the same speed with th same load, 2 people cooler. I'm thinking the exhaust will bump it up plenty. Just my .02.
1754 ProDrive X series
36Hp ProDrive
Fri Aug 20, 2010 1:38 pm
I wonder if any company is planning on coming out with some modded coils with a 5100 rpm rev limit built in? If they did, it would probably make the older ignition system obsolete on the higher performance engines with the higher rev limits.
"We Are Products Of Our Decisions"
Fri Sep 03, 2010 10:00 am
That is correct Chico!! :lol:
Fri Sep 03, 2010 10:41 am
Yep
Fri Sep 03, 2010 10:54 pm
Chops.. Im think about getting that card soon.. I was wondering about the new black death intake also.. Is this needed being I would only have muffler and carb?!?!
Tue Sep 07, 2010 1:14 pm
If you're gettin the carb, it'll come with the adapter for your intake, the BD intake isn't necesary, but will give added gains in performance.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Tue Sep 07, 2010 5:22 pm
That's what I was wondering if it would help a little more bring it would be more air. But I wasn't sure if it would help being I don't have any internal work done nor do I plan to. Muffler and carb is all I plan. But if the bd intake will help I'll also think about that when buy'n the carb
Tue Sep 07, 2010 6:03 pm
My throttle lever already cracked and broke... Anyone have any replacement tips on a better design
Fri Sep 10, 2010 3:33 pm
Users browsing this forum: No registered users and 122 guests
cron
