It is currently Sun Jun 29, 2025 9:45 pm
Reply to topic  [ 6 posts ]
 Electronic Fuel Pump Question
Post Electronic Fuel Pump Question
The more i read on this forum the more i think i need to install a e fuel pump on my 25hp kohler gd longtail. So ive got some questions. Do i bypass the mechanical fuel pump? Do i take the primer bulb out? Do i just wire it to the ignition switch? Thanks for the help guys i need to get this sucker running ive got t minus 29 days and counting for the small duck season.
Thu Aug 12, 2010 10:26 pm
Post Re: Electronic Fuel Pump Question
I installed one last year, and it made a big difference for me. The engine runs much better, and starts right up. I wired the Fuel Pump directly into my starter. Turn the key, let the Fuel Pump run for a couple of seconds and then start it up. You need to check to see if your fuel pump is a push or a pull pump. Mine is push which should be installed as close as possible to the fuel tank. I have the fuel pump installed on the bow, and then the line runs into a primer bulb, into a water seperater, into a quick connect, and into the engine. I originally took the bulb and quick connect off and ran the motor, and then put them back on, and ran the motor. There was no noticeable difference for me, so I put them both back on. The bulb is a back up in case the Fuel pump goes out, and I like having quick connect to burn the fuel out of the motor(much easier, and I do this about every time I run the engine). The only thing you could add is cut off switch to the fuel pump so you can turn it off. I hope this helps.
Thu Aug 12, 2010 10:49 pm
Fri Aug 13, 2010 6:26 pm
Hey guys thanks for the help i just got a mr gasket e pump bout to go install will post some results after i get it on
Fri Aug 13, 2010 7:20 pm
How did the install go and did it improve the way your motor runs?
"We Are Products Of Our Decisions"
Gator Trax 1750HD With Mud Buddy Black Death 5500
Mon Sep 13, 2010 3:39 pm
still trying to work bugs out of the motor so i took the thing off ill let ya know when i get everything running
Mon Sep 13, 2010 4:05 pm
Users browsing this forum: No registered users and 124 guests
