It is currently Sun Jun 29, 2025 10:00 pm
Reply to topic  [ 7 posts ]
 Kohler help needed
Post Kohler help needed
I have a Kohler CH15 motor that I mounted on a longshaft frame and it is bogging down too easy under load. The RPMs are fine out of the water. Is there a way to adjust the governor so that it will stop doing this or do I need to disconnect the governor ? I have already performed the governor adjustment (the way the factory told me to) by loosening a nut and pulling the governor arm away from the carb....turning the shaft counterclockwise and tightening the nut (this was already turned as far as it would go counterclockwise). Are governors usually on mud motors ?
Any input will be appreciated.
Tue Sep 14, 2010 7:27 pm
Post Re: Kohler help needed
How's your compression?
Tue Sep 14, 2010 7:29 pm
Good. Motor is new. Kohler tele help is worthless........they don't want tell me what else to do because of warranty issue. I tried to explain to them that I was not concerned about warranty but an engine that would push my boat well.
Tue Sep 14, 2010 7:40 pm
kinda need more info
boat size?
size of prop?
how big ole boy are you?
Tue Sep 14, 2010 7:55 pm
1544 boat ..........8 x 4 prop ...........175lbs
Tue Sep 14, 2010 8:21 pm
Fixed.......thanks to cb5331......he should work for Kohler.
Sun Sep 19, 2010 9:40 am
Hey man ive got the same problem what ended up being the problem?
Mon Sep 20, 2010 7:48 am
Users browsing this forum: Majestic-12 [Bot] and 132 guests
