It is currently Mon Jun 30, 2025 10:35 pm
Reply to topic  [ 13 posts ]
 new marine engine by briggs & stratton digital CDI
Post new marine engine by briggs & stratton digital CDI
I been having a 31hp gator-tail for 8years and i just upgaded to the new marine engine how are the new 35hp marine engine. The good and the bad things about the engine.
18ft by 4ft flat bottom 35hp marine engine and mm exhaust
Tue Nov 02, 2010 5:04 pm
Post Re: new marine engine by briggs & stratton digital CDI
fresh paint my new marine engine
Tue Nov 02, 2010 7:07 pm
The only thing that's bad that I can think of with these engines is that they are limited to 4300 rpm. If you decide to upgrade the motor you're going to hit the rev limiter real quick. Other than that, I think they are much better engines and run a lot smoother.
Wed Nov 03, 2010 6:56 pm
Thanks for the reply on my post
Wed Nov 03, 2010 7:47 pm
I have no complaints about mine, very smooth and fires right up on first few revolutions, even when cold.
One thing I have heard though and noticed on mine is when you take off, if you squeeze the throttle to wide open it will tend to bog down. Sometimes you kind of have to gradually give it the gas to get to WOT.
35 hp CDI MB HD Sport pushing a 17'6" Uncle J custom bateau
Thu Nov 04, 2010 3:14 pm
Thu Nov 04, 2010 3:56 pm
Can fix the acceleration problem
Thu Nov 04, 2010 6:07 pm
Mines runs good but like they said it bogs down when you give it wot and its always hard to start, cold or hot i have to work it a little to get it running
18x58 w/healthy GTR 35
"A good friend will bail you out of jail but a true friend will be sitting by you saying damn that was fun"
Thu Nov 04, 2010 6:15 pm
My 35hp gt cdi runs fine and start up on first crank but I have dead spot in the throttle when I take off
Thu Nov 04, 2010 7:34 pm
The CDI (marine grade) is the 35 Briggs with different coils that have a built in rev limiter and an electronic timing advance- gives more power than a stock motor. The coils allow it to idle very smoothly at much lower RPM than the stock 35. It has a different fuel pump operated off the vacuum from the intake and better wiring. A big plus is the CDI has a 50A charging system that charges at idle. The stock CDI comes with a stainless steel version of the stock muffler as well.
The CDI has the same stock carb as the stock 35 and the bog down mentioned above is similar to some of the 35/36s CDI or not- its can be adjusted out.
Thu Nov 04, 2010 8:22 pm
I have twin Mikuni's on my CDI and it starts up instantly and doesn't bog down when I jam on the throttle either. So like DB8 says, you should be able to adjust all of that out.
Tue Nov 09, 2010 1:13 pm
SImple fix, mukuni's take the bog out of you motor!
Tue Nov 09, 2010 10:20 pm
:) Got it fix by a local mechanic fix the problem thanks for the good information on my motor
Wed Nov 10, 2010 7:10 pm
Users browsing this forum: No registered users and 126 guests
