It is currently Mon Jun 30, 2025 8:13 am
[ 8 posts ] |
FFT
Joined: Tue Nov 02, 2010 7:19 am Posts: 50 Location: NJ
 LTGD prop question.
The prop on my 98 gd has a quarter turn play on the shaft. The stop nutz infront and behind the wheel are tight. Is this a normal setting or should I tighten up on the nutzs?
Fri Nov 19, 2010 8:32 am |
Gigafowl
 Re: LTGD prop question.
You are OK... Some folks liked to keep them that way so they were easier to remove later.... Unless it is making too much noise and that is buggin you - just leave it that way....
4 or 5 Lil pumps of grease into the shaft every other outing and a half pump into U joints every 20 to 30 hours - change oil at same 20 to 30 hour interval and you are - good to go...
Fri Nov 19, 2010 8:41 am |
FFT
Thanks, also the engine tends to backfire when I have the rig overloaded and the throttle wide open. The plugs look good. Any tips?
Fri Nov 19, 2010 8:59 am |
Gigafowl
Muffler ???
Call GoDevil - you need your frame SN which is just behind the engine under the U joint - to talk to 'em and maybe order parts....
Fri Nov 19, 2010 9:13 am |
cbrown
Joined: Wed Aug 04, 2010 1:45 pm Posts: 108 Location: Dallas, TX
I've heard that if you put low grade gas in the motor it will backfire sometimes. Not sure why.
_________________ 09 1848 PD X-Series/ 36 PD
Fri Nov 19, 2010 9:15 am |
take'emgator
Joined: Mon Oct 19, 2009 6:38 pm Posts: 10201 Location: SETX
This is true!
Fri Nov 19, 2010 3:03 pm |
retired and broke
Fri Nov 19, 2010 3:14 pm |
Gigafowl
Fri Nov 19, 2010 9:21 pm |
[ 8 posts ] |
Users browsing this forum: No registered users and 116 guests |
