It is currently Mon Jun 30, 2025 8:13 am
Reply to topic  [ 19 posts ]
 Brand new 36pd
Post Brand new 36pd
Just bought my 36pd and put it on a sportsmanfab I'm already looking to get some mods put on it and I'm was just looking for some suggestions on what would be best to put on it
stage 3 GTR screaming behind the 1848 Garrett Pearce special. GET YOU SOME!
Wed Nov 03, 2010 11:30 am
Post Re: Brand new 36pd
Get your heads decked, put oversized stainless valves in, and either shim your valve springs or replace wit double wound springs. Also get a stainless aftermarket exhaust dat flows better.
After that if you still want more you can get a better cam, or carb, or both.
Wed Nov 03, 2010 11:40 am
Wed Nov 03, 2010 8:04 pm
He has that on auto post i think.
Team Arc Angel Bowfishing
Wed Nov 03, 2010 8:06 pm
Yup. Not much more to say bout that...
Quack and Cb what you think it would set that man back getting all the things you listed above done?
Wed Nov 03, 2010 8:08 pm
Depends where you go... For everything listed above I'd say around 2500 +/-
Wed Nov 03, 2010 8:12 pm
Whats going to hit you the hardest? The heads?
Wed Nov 03, 2010 8:13 pm
Wed Nov 03, 2010 8:14 pm
Yeah, prolly carb. Depends on what all you do with the heads. With rr's, ss valves, springs, port work, and decking, you get pretty close to a grand. No rr's or new springs save you few hundred bucks... Really depends on who is doing the work though.
Wed Nov 03, 2010 8:16 pm
I have see the used carbs on here how much does a new one go for?
Wed Nov 03, 2010 8:17 pm
Im gunna see how much we can make this honda up to after duck season, have a friend with a damn good machine shop. :twisted:
Wed Nov 03, 2010 8:43 pm
i did my heads, cam, jetted my stock carb, exhaust, shimmed my valve springs, and advanced my timing for 1700 bucks with labor involved in all of that.......well worth the money and plenty satisfied with the results.
Thu Nov 04, 2010 6:40 am
Thu Nov 04, 2010 6:52 am
But on the other hand these mods will help you tremendously!
Thu Nov 04, 2010 6:54 am
I would say you would have 200+ in gaskets, and have to pay someone to install the cam if you didnt know how. I have about 1650 in my heads, carb, exhaust, gaskets. I got a little bit of a deal when I bought it all at once from keith. and back then the cross over exhause was 480, instead of 399 like it is now.
Thu Nov 04, 2010 7:05 am
Supply and demand!
Thu Nov 04, 2010 7:51 am
Thu Nov 04, 2010 8:49 am
Ight fellas ordered me a new mm double barrel x and a 43 mikuni. And recomindations on heads as far as were to bring them or were would be a good place to have them done and thanks for pointing me in the right direction
Thu Nov 18, 2010 7:15 pm
Users browsing this forum: Google [Bot] and 116 guests
