It is currently Tue Jul 01, 2025 1:49 pm
Reply to topic  [ 16 posts ]
 Help! Cam!
Post Help! Cam!
I need a cam for a mudbuddy hd 5000! anyone know where i can get one asap!
Wed Nov 17, 2010 7:19 pm
Post Re: Help! Cam!
chops @ setx performance
Wed Nov 17, 2010 7:20 pm
Post Re: Help! Cam!
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Wed Nov 17, 2010 9:23 pm
Post Re: Help! Cam!
I'm gonna call setx first thing in the morning and see if i can get them to overnight me a cam.
Now as far as installation? how big of a pain in the ass is this gonna be? I'm not a complete idot when it comes to working on cars and trucks, but i'm not a genius either. anyone got some tips or hints for me?
Wed Nov 17, 2010 10:41 pm
Post Re: Help! Cam!
You would get alot more product specific info on the MB forum, just sayin. I saw your post there and will point you to some threads with step by step.
Get a case cover gasket set and the two o-rings (call BoatDr he usually has them in stock). Also make sure you have a belt tension test gauge for when you reinstall the outdrive.
Thu Nov 18, 2010 2:45 am
Post Re: Help! Cam!
Thu Nov 18, 2010 8:22 am
Post Re: Help! Cam!
Mon Nov 22, 2010 9:52 am
Post Re: Help! Cam!
hell no! ended up taking to the dealer, got it back last thurs and took it out to run sat. something still isn't right with it so it went back to him sunday. it's still blowing oil out of the carb and won't get over 4000 rpm in the water. i'm honestly thinking something else went bad when the lobe on the cam went out. dealer called me today and said it might be a head gasket, but i'm thinking more along the lines of a busted ring or piston. but we will see!
Mon Dec 06, 2010 1:45 pm
Post Re: Help! Cam!
Where are you located?
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Mon Dec 06, 2010 1:49 pm
Post Re: Help! Cam!
Laurens, SC
Mon Dec 06, 2010 2:33 pm
Post Re: Help! Cam!
Could it be a stuck valve? Same thing happened to a friends of mines motor and a push rod had fell out which made his valve stick put it back under the rocker problem solved.
Mon Dec 06, 2010 7:35 pm
Post Re: Help! Cam!
def not a stuck valve. he did a leak down test today and is going to go into the motor tomorrow to see what the news is gonna be! i just really hope its a bad head gasket!
Mon Dec 06, 2010 8:35 pm
Post Re: Help! Cam!
Tue Dec 07, 2010 8:53 am
Post Re: Help! Cam!
got the call earlier today that it's a blown head gasket! he's suppose to be taking it out on the water this afternoon for a run to see how she does! i might just get lucky and have it back in time to hunt the 2nd split!
Thu Dec 09, 2010 3:49 pm
Post Re: Help! Cam!
Compression/leakdown would have IDed that quickly. Hope thats it and its good to go.
Sat Dec 11, 2010 10:18 am
Post Re: Help! Cam!
I thought this was a get help thread for Cam Newton. Carry on.
My motor doesn't have docking assistance, it has REVERSE!
Sat Dec 11, 2010 10:23 am
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 188 guests
cron
