It is currently Sat Jul 05, 2025 11:07 pm
Reply to topic  [ 24 posts ]
 scary noises
Post scary noises
i have a stage 1 with evt 493f cam and at 2000 rpm's my motor has a knocking noise. is it just something they do or what?
Sun Feb 13, 2011 9:52 pm
Post Re: scary noises
Rod knocking?
Sun Feb 13, 2011 9:56 pm
i dont think so it doesnt do it at idle or after 2400 rpm im not sure what it is. ive heard of something called a timing knock,any input on that.
Sun Feb 13, 2011 10:02 pm
didnt you say you had a timing key in it ? you might have to much or not enough. might be that rpm range on the cam?
Sun Feb 13, 2011 10:18 pm
thats what im thinking. if someone with a 493 reads this please input
Sun Feb 13, 2011 10:20 pm
You tried calling Mike?
no, is that evt?
Sun Feb 13, 2011 10:22 pm
if a mm cam is anything like a car cam its going to have an operating range where your going to get all your HP at certain rpm's. that might be the low end of the range
Sun Feb 13, 2011 10:23 pm
yea its hard to explain it, its not rodsor bearings its almost sounds like its coming fro the flywheel maybe power band.idk
Sun Feb 13, 2011 10:25 pm
Sun Feb 13, 2011 10:28 pm
got cam from a friend and everything else bps, but will def call him. dont rememberit doing that with hoyt cam but also didnt have timing key.
Sun Feb 13, 2011 10:30 pm
Hey Garrett jsut squeeze the throttle and have fun hahahahahaha
Sun Feb 13, 2011 10:36 pm
thats what ive been doing and works so far but trying to make it to tx. lol
Sun Feb 13, 2011 10:37 pm
Put it in the garage and wait till the 25th-27th to pull it out and run it
Sun Feb 13, 2011 10:39 pm
wont work so well im an addict.
Sun Feb 13, 2011 10:40 pm
is it a CDI motor?
Mon Feb 14, 2011 4:32 am
No
Mon Feb 14, 2011 8:15 am
Some engines do that....My engine has always done it. It doesn't do it near as bad if I run premium gasoline. It almost sounds like detonation....if your already running good gas don't worry about it.
Mon Feb 14, 2011 8:22 am
Mon Feb 14, 2011 8:32 am
What timing key did you put in it? At the most with that cam you would want a #5 with premo gas. we do not put nothing bigger than a #3 in the 35 and a #5 in the 31. It did not do with the bigger cam do to the compression was being bled off from the longer duration and is a top end cam.
Mon Feb 14, 2011 9:43 am
I have # 3
Mon Feb 14, 2011 12:31 pm
That their noise is the ticking on the bomb!! :lol:
17x48 extreme stage 2 GTR
Mon Feb 14, 2011 5:59 pm
Mon Feb 14, 2011 6:54 pm
Profile YIM
na men, got to have faith.
Mon Feb 14, 2011 9:28 pm
Users browsing this forum: No registered users and 146 guests
