It is currently Wed Jul 02, 2025 7:22 am
Reply to topic  [ 12 posts ]
 ProDrive Vibration
Post ProDrive Vibration
How much felt vibration is normal for a PD36? I bought a used lower unit and repowered, and although everything looks to be running straight, after 10 minutes at 3500RPM my arm starts to get numb from the vibration.
[size=85][/size] Janky-ass Triton 1650 with an 06 PD frame, 09 PD LU, Generac slightly modded, Mikuni 42, and a bunch of bolts I found in a coffee can holding it all together.
Mon Feb 14, 2011 3:32 pm
Post Re: ProDrive Vibration
Unbalanced prop?
Mon Feb 14, 2011 3:56 pm
Corpal tunnel? Hits me hard with the twist grip. I roll the throttle and then just keep a little pressure on top the grip with my hand and don't grip it. Works much better for me.
18x48 Charles Leonard / 36PD
Mon Feb 14, 2011 6:14 pm
Mon Feb 14, 2011 7:23 pm
On long runs I grab the rubber way back where it meets the metal I
Find it easier to hold
Aucoin 20X48 36pd
Lock your wife and your dog in the garage for an hour. Then open it and see
who's happy to see you.
Mon Feb 14, 2011 7:25 pm
Mon Feb 14, 2011 7:46 pm
balance your prop
24x60 Dual Prodrives
Mon Feb 14, 2011 8:48 pm
Ok, two folks said balance the prop....how? I don't mind sounding ignorant, when that is exactly what I am. I'll also try not hangin on so tight (probably a good idea in case I hit anything)
Thanks for all the guys on here who don't mind sharing some knowledge and experience, so we all benefit!
Mon Feb 14, 2011 9:08 pm
Take it to a prop shop and have it balanced. Call around in your area, there is probably more than one. Tell them what you have and get a quote. Take it to who you are most comfortable with.
Mon Feb 14, 2011 9:30 pm
If you have CT- try a bike glove (fingerless w/ padded palm) on your throttle hand. Helps dampen the vibration.
Tue Feb 15, 2011 6:54 am
I had bad vibration with a new pd prop, had it balanced, still no help talked to Peck at pd sent it back to him. He said it had a warped blade and must have come out of the mold to hot, so he sent me a new one.
1754 Gatortail with 35 GTR
1748 prodrive pushed by a genny (SOLD)
I shoot black mallards does that make me guilty of a hate crime?
Fri Feb 18, 2011 1:36 pm
Well, I am going to remove the prop, and run it on the trailer at idle, to see if the problem is there. If it still vibrates without the prop, I'll know the problem is somewhere else.
Fri Feb 18, 2011 9:57 pm
Users browsing this forum: No registered users and 106 guests
