It is currently Wed Jul 02, 2025 5:49 pm
Reply to topic  [ 8 posts ]
 engine rpm
Post engine rpm
i have a mb 45mag. my tach says it is idling at 1200 rpm's. is this right? cuz it really dont sound like its idling that high.
17x50hd gator trax 45mag mb
Fri Feb 11, 2011 6:45 pm
Post Re: engine rpm
Thats right. If you tach was bad it would read either 1/2 or not at all is what I have seen.
Fri Feb 11, 2011 7:46 pm
Post Re: engine rpm
but while im running it reads like 14,000. the motor is brand new
Fri Feb 11, 2011 9:16 pm
Post Re: engine rpm
Well i can tell u that something is wrong somewhere i had a tach do that to but it said i was idelin at 2250!!!! and i switched the ground and the red wire to the other side of the motor and it startin workin right and then like 2 days later did the same thing so i changed tach and everything was fine after that!!! and if it's brand new it should be under warranty!!!
Fri Feb 11, 2011 9:20 pm
Post Re: engine rpm
ok thanks. ill look into it.
Fri Feb 11, 2011 10:14 pm
Post Re: engine rpm
Fri Feb 11, 2011 10:18 pm
Post Re: engine rpm
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Fri Feb 11, 2011 10:50 pm
Post Re: engine rpm
Jet engine RPM is read in % not RPMs
Wed Feb 16, 2011 1:04 pm
Users browsing this forum: Google [Bot] and 185 guests
