It is currently Thu Jul 03, 2025 2:59 pm
[ 7 posts ] |
smboudreaux
Joined: Mon Nov 22, 2010 7:10 pm Posts: 162 Location: Addis, LA
 why do these motor fail?
after reading through many pages here i'm beginning to understand that once you mod past a stage 1 setup the life span appears to drop of drastically. technically what is the common weak point? cracked block? thrown rod? valves dropping out? is the common cause the higher rpm's or are the motors unable to process out the added heat causing fatigue on internals of the cylinder sleeves themselves?
how many hours are the guys running stage 2 and stage 3 motors actually getting out of them?
Sun Mar 27, 2011 4:47 pm |
quackconsumer
 Re: why do these motor fail?
The blocks can't seem to handle the compression. But there is no one reason being how they are modded so many different ways.
Sun Mar 27, 2011 5:28 pm |
smboudreaux
i noticed the new vangaurds have a sleeved block. i built turbo'd 4 bangers for a while. blocks not handling compression is nothing new. i know air cooled vs water cooled in apples and oranges but we'd sleeve sleeve open deck honda blocks before we'd slap a big turbo setup on it. in theory, since vanguard blocks are already sleeved, could the factory sleeve be pushed out, the block reamed and a thicker, stronger sleeve be pressed in?
have the blocks always been sleeved or is this something knew with the onset of the CDI era motors?
Sun Mar 27, 2011 7:00 pm |
craig
Joined: Tue Jan 13, 2009 7:53 pm Posts: 7515 Location: Chauvin
_________________ 1750 GatorTail Extreme/Stage 3 37 GTR HD Procrastination is a lot like masturbation. Sure it sounds great at the time but, in the end your only f--k--g yourself.
Sun Mar 27, 2011 7:07 pm |
deadbird8
Depends on the recipe used for the mods. You can get 100's of hours on motors with cams, pistons, c-rods, etc... The MB45 is a very reliable motor. Running race oil in them is recommended.
Sun Mar 27, 2011 7:08 pm |
keystone light
Joined: Mon Dec 27, 2010 4:04 pm Posts: 320 Location: Setx
What kind of race oil do you recommend deadbird? I have a mb 45 .
_________________ 17x50hd gator trax 45mag mb
Sun Mar 27, 2011 9:16 pm |
XGEN-DUCKMAN
Joined: Fri Jan 16, 2009 3:51 pm Posts: 195 Location: BackWaters of Wisconsin
Seems like as soon as the compression starts getting over the 190's the issues arrive, that and as soon as you start running over 4600rpm's........ I put my 2nd 45mag through the paces and she did fine....... just keep her running under 4600rpms and you should be good..
As far as oil goes, a high zinc racing oil is what you want....anything that says "not for road use" racing oil...........10W30
_________________ If I can't Break it, it can't be Broke.............................
Sun Mar 27, 2011 11:49 pm |
[ 7 posts ] |
Users browsing this forum: No registered users and 168 guests |
