It is currently Thu Jul 03, 2025 8:39 am
Reply to topic  [ 55 posts ]  Go to page 1, 2  Next
 Dguidry Begins Installing New Heads Today! Suggestions.
Post Dguidry Begins Installing New Heads Today! Suggestions.
Well, picked up my new performance heads today. A question: do the new head gaskets require adhesive or sealant, or do they install dry? Do I use locktite on the head bolts? Anyone know what the numbers and symbols on the valves mean?
Heres a pic;
Wed Mar 23, 2011 6:59 am
Post Re: Dguidry Begins Installing New Heads Today! Suggestions.
Those symbols are the briggs logo
Wed Mar 23, 2011 7:08 am
I=intake
E=exhaust
dry and torque to specs, I prefer to snug up first, then go in a cris cross pattern to tighten up. locktite on head bolts won't be a bad idea.
When in doubt, throttle out.
18x60 prodrive w/36 prodrive
Wed Mar 23, 2011 7:12 am
I use a "copper spray a gasket" on the gaskets. Loctite on the bolts is fine. I would not use red though. Probably blue.
Wed Mar 23, 2011 12:24 pm
Post Re: Dguidry Begins Installing NPew Heads Today! Suggestions.
Heads are bolted to cylinders. Specs posted here say torque head bolts to 340 foot lbs? My torque wrench only goes to 150? Should I just tighten the mothers as hard as I feel comfortable or what?
Wed Mar 23, 2011 6:36 pm
Think you have inch pounds and foot pounds mixed up.
Wed Mar 23, 2011 6:44 pm
Go for it!!!! Tell us what happens!
Wed Mar 23, 2011 6:45 pm
Ok, YOU ASSES! Just realized the specs were in "in lbs"!!!! So y'all were just waiting for me to post the eminent catastrophe, weren't y'all?
So just how many foot lbs is 340 in lbs?
Wed Mar 23, 2011 7:24 pm
Divide 340 by 12 and you will get your answer.
Don't mistake my kindness for weakness, my ability to look over things as ignorance - but make no mistake, when I've had enough, I'm Coming After you. Watch Your Back....lol
Wed Mar 23, 2011 7:27 pm
you should probably get a inch pound torque wrench before tearing something up. they cost a little more than the ft pound wrench but a lot cheaper than trying to put 340 ft pounds on them bolts.
Wed Mar 23, 2011 7:30 pm
lefty loosie, riighty tighty...
and don't forget to buckle your helmet...
Sometimes it's best to just keep your fingers quiet...
Wed Mar 23, 2011 7:37 pm
rent a wrench at AZ or Oriellys
1850 & 36pd
Wed Mar 23, 2011 7:43 pm
Is that head on a silver platter? :lol: :lol:
1648 weldbilt pushed by a Mudbuddy 35hd
" People are like slinkies pretty well useless, until you see one go down the stairs then you smile."
Wed Mar 23, 2011 7:44 pm
yall must not get it, he has to be posting shit like this to make ya'll talk. noone can really ask if he should put locktite on a head bolt or silicone on a head gasket. WOW!!!!!!
Wed Mar 23, 2011 8:01 pm
1850 & 36pd
Wed Mar 23, 2011 8:11 pm
340 in lbs = 28.333 ft lbs.
My head bolts are just right they ain't ever coming off again without striping bolt heads. No locktite and no antiseize. I don't know who to trust anymore except a few. So if your intent is evil payback will be a sob for you.
Wed Mar 23, 2011 8:35 pm
Never seize would have been a wise move.
Wed Mar 23, 2011 8:50 pm
Wed Mar 23, 2011 8:53 pm
So they "never seize" and they are way easier to break loose if you need to take it apart for whatever reason.
Wed Mar 23, 2011 9:00 pm
ahh
Wed Mar 23, 2011 9:04 pm
Wed Mar 23, 2011 9:18 pm
Things are coming along nicely. Done for the evening. Should be finished tomorrow.
Rods
New sparkplugs
Throttle assembly
skirting
Cowling
Muffler
Fill crankcase and transmission with oil, grease prop shaft.
Set valve lash
crank her up
The big unknowns: rigging throttle without governor and
Carb adjustment.
Wed Mar 23, 2011 10:13 pm
Thu Mar 24, 2011 5:46 am
Did you pick up a rev limiter?
Thu Mar 24, 2011 8:14 am
Once again .... I learnt sumthin' !!!! Not that I'll ever use it in a real life application ... I ain't much of a mechanic ..... Dguidry ..... keep goin' I'm enjoyin' this.
Who'ed thunk it ...... ft. lbs. vrs in. lbs. !!! :lol: :lol: :lol:
Thu Mar 24, 2011 8:35 am
Thu Mar 24, 2011 11:21 am
Early this morning I installed intakes, skirting, throttle assembly, cowling, fuel pump, electrical grounds. Thank god for the iphone camera and the photos I took of the dis-assembly!!! Tonight I'll install the flywheel guard and pull rope.
Need some help: Since the governor is no longer in the picture I'm gonna have to rig up a spring mechanism to bypass it to bring back the throttle to idle. Anyone care to conjure up a solution. I'm just not seeing how I'm gonna use the idle arm assembly in a way to spring back the throttle because is attaches to the vertical governor rod which pivots. Maybe I could somehow jam the pivot rod so it won't move so that I can attache a spring to it to pull back the throttle. Without a visual its hard to tell what I'm asking. I'll try to post something in a minute or two for a reference.
Thu Mar 24, 2011 11:33 am
TTT pics posted
Thu Mar 24, 2011 11:43 am
Thu Mar 24, 2011 11:56 am
Any suggestions on the throttle assembly would be appreciated.
Thu Mar 24, 2011 2:06 pm
After you tourqe them boltz you should have went back and tapped them with a ball pean hammer and then retourqe again dude.
1542 stuck to a 27mini. She gone.
1746 with a modded 35 gdsd
Capt Team total asalt
Thu Mar 24, 2011 6:18 pm
Thu Mar 24, 2011 6:34 pm
Go to auto parts store & pic up some misc carb springs. They will have a multi pack on their "Help" isle. Hook 1 end to the same tab that the spring is hooked to right below your thumb in the 2nd pic. Hook the other end to the vertical tab that's just above the crankcase bolt on the top right in the 1st pic. If you route it on the outside (away from the motor) of the govenor rod, it should act as a return. If not you get the idea, just relocate it until it does.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Thu Mar 24, 2011 6:35 pm
Thu Mar 24, 2011 6:36 pm
Thu Mar 24, 2011 6:43 pm
Thu Mar 24, 2011 6:44 pm
Thu Mar 24, 2011 7:17 pm
Interesting.
Thu Mar 24, 2011 7:34 pm
Thu Mar 24, 2011 7:46 pm
Users browsing this forum: Google [Bot] and 108 guests
