It is currently Wed Jul 16, 2025 10:50 pm
Reply to topic  [ 34 posts ]
 BPS on a pro drive
Post BPS on a pro drive
Ive searched and searched, and cant find a solid answer.. does bps make a crossover for a prodrive, and if not, is their anyway that it can be somehow fitted on there? What other pipes are made that fit pro drive, that are just as loud, if not louder?
Tue Apr 05, 2011 9:56 pm
Post Re: BPS on a pro drive
Yes they do make one specifically for the prodrive, only difference is the location of the exit port.
Wed Apr 06, 2011 8:05 am
I have a BPS crossover on my 36PD. Call Micah at mudbuddy and he will ship it to your door.
18'x54"CC Hanko/ 36PD
Wed Apr 06, 2011 9:24 am
Alright sweet, thanks guys I appreciate it! The crossover is one of the loudest pipes made right?
Wed Apr 06, 2011 9:53 am
If i'm not mistaken it is the loudest in my opinion, i ran one and took it off cause it was too loud plus i wanted to try the new Marsh Mellow
Wed Apr 06, 2011 9:55 am
Good lol, I want the thing to sound like a harley
Wed Apr 06, 2011 10:00 am
I heard they are about to stop making them for the PD, the crossover anyway.
Problems with them falling apart
Pro Drive m'fers
Wed Apr 06, 2011 10:20 am
lol I dont expect to spend that much for a exhaust that will just fall apart.. Doesent hogg build a pipe for pro drive that is equivalent to the crossover as far as how loud it is?
Wed Apr 06, 2011 10:24 am
Pro Drive m'fers
Wed Apr 06, 2011 10:31 am
Lol that's just great.. So what's a pipe worth a crap that still has good sound?
Wed Apr 06, 2011 11:43 am
Pro Drive m'fers
Wed Apr 06, 2011 11:46 am
I've always liked it for some reason.. Im sure ill get tired of it eventually and when I do ill just buy something else.
Wed Apr 06, 2011 11:57 am
BPS redesigned the supports for the crossover to fix it's problems. It is loud, but u can install the baffle anytime to reduce the sound quite a bit.
Wed Apr 06, 2011 12:04 pm
I didn't think it was the supports causing the problems. I was told that its how the exhaust sat so close the the water that when your running it the cooler water was always spraying up and hitting the hot exhaust and causing it to crack near the welds. I could be wrong though
Wed Apr 06, 2011 12:08 pm
Wed Apr 06, 2011 12:12 pm
The marshmallow has 2 versions, the original one and the x. The x is supposed to be louder with no baffles and the original which is pretty quiet. I have the original.
The x is pretty new so somebody else would need to comment on it's volume.
Wed Apr 06, 2011 1:27 pm
I agree with Owen I have a crossover on mine water hardly ever hits it. It has all the new braceing and I still have a crack. But that was after 100 plus hours of beating the sh@# outta it
Wed Apr 06, 2011 1:30 pm
I have the new Marsh Mellow and it is very nice, same performance as the BPS in my opinion just not nearly as loud, and has a bad to the bone rumble and WOT sound
Wed Apr 06, 2011 1:42 pm
I doubt many of you have the new bracing, only just came out. Its reinforced where the brace hits the crossover pipe. They had problems with the welder getting hot and making it brittle as a fail point. It was not water splashing on it.
Brasso - you don't look very hard. Been out for a long while.
Crossover:
'Q'
Wed Apr 06, 2011 6:26 pm
I appreciate all yalls help,Im not to worried about it cracking every now and then everything does, and deadbird, thanks for the pics podna, I didint really search too too hard either no, you are correct. I wanted to get a good idea of everyones opinions on it and how it was constructed.. They answered most all the questions about it without me even having to ask them
Wed Apr 06, 2011 6:50 pm
Look at my pic of my BPS. I just got in and installed it . I was told by Micah it was the new re designed model, because my concern was also the cracking.
Wed Apr 06, 2011 7:28 pm
Awsome, this makes me want to go out and buy one tomorow.. How much are the pipes.. and so I dont start another thread,
How much is it to add hydro tilt, and reverse to a manual pro drive unit?
Wed Apr 06, 2011 7:36 pm
Wed Apr 06, 2011 7:49 pm
Wed Apr 06, 2011 8:00 pm
If I can't Break it, it can't be Broke.............................
Thu Apr 07, 2011 4:49 am
The heat don't hep things but it is the vibration that is breaking the mufflers 10 fold on stainless. Stainless work hardens therefore the welds or the heat effected zone of the welds is what normally cracks. To keep one from breaking as soon the material must be thicker with as little welding as possible. If the materials are too thin then you will see actual brackets and flanges break as well. Heat makes metal expand and if that metal is locked in tight and has nowhere to move then it will sooner or later crack or break something. Mufflers should also be built from a higher grade stainless other than 304L like 316L minimum but the best would be a 321H or 347 grade. of course price gets higher with the upgrade in stainless. I think Inconel would be the best material to use but that would cost way too much to build.
Thu Apr 07, 2011 5:32 am
Thu Apr 07, 2011 8:05 pm
1754 Gatortail with 35 GTR
1748 prodrive pushed by a genny (SOLD)
I shoot black mallards does that make me guilty of a hate crime?
Thu Apr 07, 2011 10:11 pm
Inconel is what they make stainless capillary strings out of, if I'm not mistaken.
24x60 Dual Prodrives
Thu Apr 07, 2011 10:42 pm
Anyone gonna answer my question bout adding hydro tilt and reverse?
Thu Apr 07, 2011 11:39 pm
Tilt. $475
Manual Reverse. $475
Full Power Reverse. $1500
Is on the website!!!
Fri Apr 08, 2011 1:40 am
Fri Apr 08, 2011 5:50 am
I tried going on the website last night and it said operation canceled each time I tried for some reason, and all I've got is my phone to get on so, I just went ahead and asked, and yes. I did actually search on here a good bit. Thank y'all for the info guys
Fri Apr 08, 2011 6:46 am
Users browsing this forum: No registered users and 121 guests
