It is currently Thu Jul 17, 2025 10:18 am
Reply to topic  [ 29 posts ]
 Carb
Post Carb
Is there a difference in the stock carb from a MB 45 Mag and a stock carb from a MB 35?
Thu Jun 23, 2011 6:58 pm
Post Re: Carb
the back fire valve is plugged off. the jets i believe are the same
Thu Jun 23, 2011 7:18 pm
Post Carb
What's different about the motor on the 45 mag?
Thu Jun 23, 2011 7:20 pm
Post Re: Carb
cam-push rods-roller rockers-pistons-rods-rev limiter. 10 hp.
Thu Jun 23, 2011 7:34 pm
Post Carb
And a stock carb can handle those upgrades? Any idea which cam? I'm wanting more power but preferably stay with a stock carb
Thu Jun 23, 2011 7:38 pm
Post Re: Carb
bps cam. a carb upgrade will only help. u don't have to have it tho.
Thu Jun 23, 2011 7:43 pm
Post Carb
Piston and rods are a different stroke than stock? Would I be better off with cam and head work?
Thu Jun 23, 2011 7:55 pm
Post Re: Carb
maybe start with a carb - exhaust. then crack open the block. and build up a stroker motor.siamese cylinders and pistons - linker carbs.alkyhaul.
Thu Jun 23, 2011 8:41 pm
Post Carb
I was thinking nitrous or maybe a twin turbo set up!
I know everyone goes to a carb and exhaust as first up grades but Im wantin to keep the stock carb that's why I'm askin if cam, exhaust and head work would be a better option then goin to new crank pistons etc that the 45 has
Thu Jun 23, 2011 8:49 pm
Post Re: Carb
how much money u want to spend. ? yes the cam kit exhaust and shimmed springs port matched and ported heads fresh valve job. will get u more than going the pistons rods route u can always build a stroker later. can i ask why u what to keep stock carb ?
Thu Jun 23, 2011 9:07 pm
Post Carb
I like the simplicity of it as far as minimal adjustments and I want to keep the stock cover for rain protection etc. I don't wanna have to worry about my carb when I get caught in a rain storm
Thu Jun 23, 2011 9:15 pm
Post Carb
Shimmed springs to increase spring pressure for higher rpms?
Thu Jun 23, 2011 9:16 pm
Post Re: Carb
yes
Thu Jun 23, 2011 9:27 pm
Post Re: Carb
Fri Jun 24, 2011 5:07 am
Post Carb
Where would I get the rods and pistons for the 45, BPS?
Fri Jun 24, 2011 7:07 am
Post Re: Carb
Thanks for that post^
like u said a different crank will allow to piston to travel further DOWN in the cylinder bore and further UP.
Fri Jun 24, 2011 7:08 am
Post Carb
What's the purpose of the longer rods in the 45? Is the crank different as well or does it increase compression?
Fri Jun 24, 2011 10:47 am
Post Re: Carb
Fri Jun 24, 2011 10:54 am
Post Carb
So how does any of this translate to more power? What gives the 45 more hp?
Fri Jun 24, 2011 11:21 am
Post Re: Carb
more compression = more power.
Fri Jun 24, 2011 12:35 pm
Post Re: Carb
Longer stroke allows the piston to travel lower in the cylinder giving you more area to fill with fuel/air mixture. The Longer stroke also puts less friction on the cylinder wall and the piston rings freeing up HP. This is due to the crank and rod driving the piston at a new less steep angle.
And most of all longer stroke give you a larger engine.
Look at the big block Chevy, a 427 compaired to a 454. The cylinder bore is the same size but the crank has a longer stroke equaling 27 more cubic inches.
Engine Size Stock Bore Stock Stroke
427 4.250" 3.760"
454 4.250" 4.000"
Fri Jun 24, 2011 3:32 pm
Post Carb
It's my understanding that the crank is the same so the stroke wouldn't change, correct? If you increase rod length but shave the piston would the compression still increase and if so wouldn't it need more fuel than the stock carb could give it? Just tryin to wrap my brain around it all
Fri Jun 24, 2011 3:42 pm
Post Re: Carb
DB8 just did a serious overhaul on his motor. Maybe he will tell us if he changed his carb when he went wif the shaved pistons and longer rods. He likes the stock carb.
18'x54"CC Hanko/ 36PD
Fri Jun 24, 2011 4:21 pm
Post Re: Carb
so what some one says i can't build a stroker motor. with out the use of a different crankshaft.? do some of u know what rod to stroke ratio means.? if u do than u also know that u can build a stroker motor. case in point i can change my piston lenght in my 40 willys coupe that is a 331 cu. and ad rod lenght and and piston pin. and have a 347 ci.no crank change.
Fri Jun 24, 2011 7:29 pm
Post Re: Carb
Just about anything can be done if you have enough money. I've honestly never heard of installing longer rods on a stock crank only to turn around and shave the pistons. Most of my exposure is to Big Block Chevy's and Harley V-Twins so maybe with a mud motor it is a common practice?
dfou, stroking an engine will not gain you very much unless the exhaust, intake, carb, heads and cam are also upgraded. You could get by with stock heads but larger valves and porting would help airflow. This would take advantave of all the other components to get more air/fuel into the cylinder.
Fri Jun 24, 2011 9:49 pm
Post Carb
Where do I find the oversize valves?
Sat Jun 25, 2011 1:27 am
Post Re: Carb
You can't just install oversize valves. The heads have to have the seats worked to accept those larger valves. A machine shop would do that for you.
Sat Jun 25, 2011 11:16 am
Post Carb
Sat Jun 25, 2011 11:23 am
Post Re: Carb
BPS IM heads come with the oversized 1 piece stainless valves and seats, shimmed springs, decked, and ported.
Others have bought the valves separately (EVT etc... ) and had them installed.
Sat Jun 25, 2011 1:44 pm
Users browsing this forum: No registered users and 122 guests
