It is currently Sat Jul 05, 2025 10:13 am
Reply to topic  [ 17 posts ]
 Belt Prices
Post Belt Prices
What do new belts run for motor? I just got my first mud motor and I'm not sure what it is, I believe it's a sport, has 29 hp Kawasaki motor on it and measures 27 inches on lower unit.
" The defenition of insanity, is to do the same thing and expect a different result."-Jase Robertson
Sun Jul 31, 2011 7:46 pm
Post Re: Belt Prices
So what u are saying is that u bought a mud motor and u don't know what brand it is? Is that correct? Post a pic maybe someone can identify it.
Gator tail
Sun Jul 31, 2011 8:03 pm
its a MB old school
Sun Jul 31, 2011 8:13 pm
Got it....thanks
Gator tail
Sun Jul 31, 2011 8:25 pm
Save yourself some $ & go ahead & change everything over to the new style whenever that old Goodyear belt gives out. Will run you about $350-400.
Sent from my Droid because I'm trying to be as cool as you someday.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sun Jul 31, 2011 8:30 pm
What all is included in swap? Is there anyway to adjust tension on belt?
Sun Jul 31, 2011 8:45 pm
1st off, you need to understand that these are not belts like on your truck's engine, they have cogs, or teeth, on them & ride on gear type pulleys.
Yes, the tension can be adjusted on them, but it's not something you should have to do very often. We're all assuming that you have a MB, is that correct? Before we can tell you how to adjust belt tension, we need to know what motor you have for certain.
The belt upgrade would consist of new top & bottom gears, & a new belt. If the belt that's on it now has cogs shaped like ^ then you have the old Goodyear belt & need to upgrade it, but wait until it breaks. The new Gates belts are tougher material & have rectangular shaped cogs.
If you do have a MB, you can get alot of MB specific info on the MB forum.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sun Jul 31, 2011 9:18 pm
It is a mudbuddy. Sport drive, I have gotta check belt
Sun Jul 31, 2011 9:48 pm
You will need to specify tall or short transom size on the belt. Tall transom will have 8 bolts on the clutch cover on the back of the outdrive, short will have 6.
Newer model belts are made of kevlar.
Mon Aug 01, 2011 5:37 am
With huntin season around the corner I would switch to the new style just for the piece of mind, but thats just me.
Mon Aug 01, 2011 6:49 am
Gator-Tail has a lifetime waranty on their belts. That's one thing MudBuddy hasn't copied yet.
Mon Aug 01, 2011 6:55 am
JC, it only comes with a new motor tho, correct? I mean, same belt, same motor, same design, but if you bought it 2 yrs ago, no warranty. At least that's what I can gather from reading about it anyhow.
I know a guy that upgraded to the new system & had a couple of the old style belts for back ups. I'll check with him to see if he still does & how much he wants for em. Shouldn't be too much, since they're now useless to him.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Mon Aug 01, 2011 7:59 am
Mine has life time warranty
Mon Aug 01, 2011 11:22 am
Mon Aug 01, 2011 6:13 pm
Mon Aug 01, 2011 6:27 pm
From down town is Craig with the 3 pointer.......AND ITS GOOD!
Mon Aug 01, 2011 8:21 pm
Wed Aug 03, 2011 6:40 pm
Users browsing this forum: No registered users and 160 guests
