It is currently Wed Jul 09, 2025 11:48 pm
Reply to topic  [ 17 posts ]
 36PD Tiller Handle
Post 36PD Tiller Handle
Has anyone ordered an extra set of rubber isolators that are B/W the handle mount and motor plate to angle the handle "up" a little higher? Its not bad but if it was an inch or two higher when driving standing I think it would be alot more comfortable.
1854 Brotha Breaux chased by 36 PD!
Wed Sep 14, 2011 8:24 am
Post Re: 36PD Tiller Handle
Go to the hardware store and get some longer bolts and some bushings and try it. I would think if you had more rubber isolators, it would get to wobbly and take away from the leverage.
I think I'll try this myself...
Wed Sep 14, 2011 11:44 am
Try shimming the motor so the handle sits at a little better angle once you get it trimmed out and running.
Wed Sep 14, 2011 11:46 am
You might end up changing the angle of your throttle linkage and it might stick a little
Wed Sep 14, 2011 11:49 am
I'll look closer when I get home but I think the throttle linkage that will be affected has the ball joint style connections, worth to take a look anyway.
Wed Sep 14, 2011 1:17 pm
I recommended shimming the motor because it won't alter anything else. Poker can correct me if I'm wrong, but I believe he did this with his to accomplish the same goal and it is working out well. Would be a lot cheaper to do it this way.
Wed Sep 14, 2011 1:28 pm
Hadnt thought about that...I will see what I can come up with this weekend! Thx for the help!
Wed Sep 14, 2011 2:27 pm
Runnin a Mikuni on it so throttle cable adjustment is easy.
Wed Sep 14, 2011 2:28 pm
Captain obvious I know, but you can never be too careful around here... :lol: I'm talking about shimming the transom bracket, not the actual engine... Just making sure that's clear. :lol:
Wed Sep 14, 2011 2:30 pm
Yep I knew what ya meant!! Glad u clarified tho i can see the posts tomorrow with tore up motors and pics of a bunch of washers under the front motor mounts!!! :idea: :lol:
Wed Sep 14, 2011 2:48 pm
Broken crankshaft, clutch busted in to pieces.... :lol:
Wed Sep 14, 2011 2:53 pm
I just looked and it wouldn't be nothing at all to shim the motor bracket and shift the angle of the whole thing. I didn't realize there were 6 bolts in the handle bracket. But IF you did raise or change the angle of the handle bracket, the throttle is no problem neither.
A couple different ways but it can be done reasonable easy.
Wed Sep 14, 2011 6:11 pm
Wait a minute, on second thought, using shims to change the angle where the motor mounts to the transom, how would this change anything? The motors sweet spot is still at the same angle of the boat no matter what the angle of the transom is...or am I'm looking at this the wrong way? You would have to either change the angle of the handle or raise the handle all together.
Wed Sep 14, 2011 6:18 pm
:lol: Lean the motor forward a little, you'll have to trim down a lil more to get in the sweet spot, and the tiller handle will sit higher. Poker, help me out. Didn't you do this with yours?
viewtopic.php?f=2&t=16139&p=176247&hilit=shimmed#p176247
I was just reading back through this and now it looks like they did what you guys were trying to do. Sorry for confusing everything... :lol:
Fuck you owen, change your damn sig! :lol: And you are right, you would not be able to trim down as far.
Wed Sep 14, 2011 6:26 pm
Then you cant trim down as much in the thick shit.
Wed Sep 14, 2011 6:27 pm
No change to the angle. What I did was add some large washers to the studs on top the rubber isolators. 4-5 in the front and 2-3 in the rear. It kicked the tiller handle up a couple inches. Any more height would call for longer bolts but I dont see why you couldn't do that either. It didnt affect the stock linkage. And that is on a tall transom. I can't drive a ST model standing.
18x48 Charles Leonard / 36PD
Wed Sep 14, 2011 6:35 pm
I went and dug up that thread now and figured out what you guys were doing. I just phucked this thread all up. :lol: Thanks for clarifying.
Wed Sep 14, 2011 6:38 pm
Users browsing this forum: No registered users and 104 guests
