It is currently Wed Sep 17, 2025 3:15 pm
Reply to topic  [ 12 posts ]
 gaskets
Post gaskets
can anyone tell me a good website where theyr buying valve cover gaskets and oil filters for 29,31,and 35 vanguards.
17x54 custom CC with stage 3 GTR.
Fri May 22, 2009 8:26 pm
Post Re: gaskets
Darrel I just use the filters from walmart,as far as the valve cover gaskets never had to get any.
What the hell you doing to that thing?
Fri May 22, 2009 10:38 pm
Post Re: gaskets
Go to any Briggs Stratton dealer, (lawnmower etc.).
They have the original filters and the valve cover gakets.
IF IT FLY, IT DIES !!!!!!!!!!
Sat May 23, 2009 4:15 am
Post Re: gaskets
Good luck finding anyone that stocks parts for the big block Briggs. Most will have to order the parts themselves so you might as well have parts sent to your house. I used these folks for a few things I have needed so far. I use the stock filters so Lowes, Home Depot or Walmart will have the them along with plugs.
http://www.outdoordistributors.com/Brig ... smain.html
18x48 Charles Leonard / 36PD
Sat May 23, 2009 7:06 am
Post Re: gaskets
Sat May 23, 2009 8:09 am
Post Re: gaskets
Ya goin deep now :lol:
Sat May 23, 2009 8:39 am
Post Re: gaskets
i know ill regret tinkering with it because once you start it never stops. hopefully ill be up again in a week or so then we can go make a run
Sat May 23, 2009 8:59 am
Post Re: gaskets
That carb kit won't do you much good if your compression is that lopsided. Get your heads fixed.
Sat May 23, 2009 10:06 am
Post Re: gaskets
no, those numbers are for 2 motors, one motor (sd) has 90 psi in both cylinders. and the lt has 140 in each cylinder. i did the carb 1st to try to gain a couple top speed mph since im only getting about 26 tops at 3600-3650 or so rpm.
Sat May 23, 2009 12:00 pm
Post Re: gaskets
http://www.jackssmallengines.com/briggs ... _parts.cfm
Sat May 23, 2009 12:01 pm
Post Re: gaskets
Sun May 24, 2009 3:43 am
Post Re: gaskets
sure is, wot out water i get 4100 but in water w/ 1 person i average 3500, i was lucky to get it to 3600-3650 a few times but when i do trim it up that much i start losing speed
Sun May 24, 2009 7:40 am
