It is currently Wed Jul 16, 2025 11:06 pm
Reply to topic  [ 12 posts ]
 Engine Fuse Corrosion
Post Engine Fuse Corrosion
Anyone had a corrosion problem on a fuse on the engine? Was getting my stuff ready tonight for a morning hunt and decided to just start my engine to check things out. Turned the key and nothing, not even a click. The trim worked fine, but nothing as far as the motor starting. After going into a panic mode, I found the fuse on the motor was very corroded. I cleaned to fuse holder and changed the fuse. Starts fine now. The fuse holder is supposed to be sealed, but it appeared to be getting very wet. I sprayed it down with some penetrating oil in hopes that this will help. Just thought I'd post this in case someone else runs into the same issue.
1754 Gatortail Extreme / 35 GTR
Fri Sep 23, 2011 9:33 pm
Post Re: Engine Fuse Corrosion
I spray cosmoline on all electrical components to keep them clean and free of corrosion. It also last alot longer than spray oil!
Fri Sep 23, 2011 9:45 pm
Where can u get that stuff? Also heard of some kind of "grease" like substance when putting new connections together but never knew where to get it?
Pete Willett
WC Custom Boats - Tyler, TX
http://www.wccustomboats.com
Fri Sep 23, 2011 9:51 pm
You can get the grease at any auto parts store. It's near the batteries.
Isn't cosmoline that shit they cover guns in to preserve them?
Fri Sep 23, 2011 9:54 pm
http://www.wisegeek.com/m/what-is-dielectric-grease.htm
1850 & 36pd
Fri Sep 23, 2011 9:56 pm
http://www.aircraftspruce.com/catalog/c ... s_rust.php
This is the product that I use. Hope this helps!
Fri Sep 23, 2011 10:12 pm
I normally use the electric grease when I'm reconnecting or doing electrical maintenace, but because the age of my motor I had no plans on working on electrical connections. I guess in the near future I'm going to check and grease all the electrical connections.
Fri Sep 23, 2011 10:25 pm
mercury marine sells a product called corrosion guard. its a spray i like it.
Sat Sep 24, 2011 7:33 am
I've had it happen once before, scraped the fuse with my knife and it fired right up.
Sat Sep 24, 2011 8:32 am
Sat Sep 24, 2011 8:36 am
Sat Sep 24, 2011 5:01 pm
Dow 111 noncureing silicone. its alot heavier than most dielectrics and can hold up to higher temps without melting off.
Sun Sep 25, 2011 8:34 am
Users browsing this forum: Majestic-12 [Bot] and 84 guests
