robertb4wd
Joined: Sat Jul 18, 2009 7:18 pm Posts: 1501 Location: Bridge City, Texas
 Engine Fuse Corrosion
Anyone had a corrosion problem on a fuse on the engine? Was getting my stuff ready tonight for a morning hunt and decided to just start my engine to check things out. Turned the key and nothing, not even a click. The trim worked fine, but nothing as far as the motor starting. After going into a panic mode, I found the fuse on the motor was very corroded. I cleaned to fuse holder and changed the fuse. Starts fine now. The fuse holder is supposed to be sealed, but it appeared to be getting very wet. I sprayed it down with some penetrating oil in hopes that this will help. Just thought I'd post this in case someone else runs into the same issue.
_________________ 1754 Gatortail Extreme / 35 GTR
Fri Sep 23, 2011 9:33 pm |
lastchance
Joined: Wed Feb 09, 2011 1:56 pm Posts: 1646 Location: Chauvin
 Re: Engine Fuse Corrosion
I spray cosmoline on all electrical components to keep them clean and free of corrosion. It also last alot longer than spray oil!
Fri Sep 23, 2011 9:45 pm |
willett
Joined: Wed Jan 14, 2009 10:22 am Posts: 1764 Location: Tyler, TX
Where can u get that stuff? Also heard of some kind of "grease" like substance when putting new connections together but never knew where to get it?
_________________ Pete Willett WC Custom Boats - Tyler, TX http://www.wccustomboats.com
WC Custom 2048 3/16 Bottom Center Console with 35 PD EFI GTR WC Custom 1840 Hybrid 3/16 Bottom with 37 EFI BOSS
Fri Sep 23, 2011 9:51 pm |
cb5331
You can get the grease at any auto parts store. It's near the batteries.
Isn't cosmoline that shit they cover guns in to preserve them?
Fri Sep 23, 2011 9:54 pm |
med
Joined: Wed Jan 14, 2009 8:25 am Posts: 6432 Location: the dark side of the moon
_________________ 1850 & 36pd
Fri Sep 23, 2011 9:56 pm |
lastchance
Fri Sep 23, 2011 10:12 pm |
robertb4wd
I normally use the electric grease when I'm reconnecting or doing electrical maintenace, but because the age of my motor I had no plans on working on electrical connections. I guess in the near future I'm going to check and grease all the electrical connections.
Fri Sep 23, 2011 10:25 pm |
richard nagon
mercury marine sells a product called corrosion guard. its a spray i like it.
_________________ JUST ANOTHER FARMER ON WELFARE
Sat Sep 24, 2011 7:33 am |
dog walker
Joined: Tue Jan 13, 2009 6:08 pm Posts: 5282 Location: Meraux,La.
I've had it happen once before, scraped the fuse with my knife and it fired right up.
Sat Sep 24, 2011 8:32 am |
duckduckboom
Joined: Tue Nov 23, 2010 6:33 pm Posts: 5603 Location: Corner of Hell an high water, La
_________________ You have your whole life to be an idiot, take a day off!
Sat Sep 24, 2011 8:36 am |
robertb4wd
Sat Sep 24, 2011 5:01 pm |
garjacker
Joined: Sat Oct 17, 2009 3:39 pm Posts: 321 Location: greensboro n.c.
Dow 111 noncureing silicone. its alot heavier than most dielectrics and can hold up to higher temps without melting off.
Sun Sep 25, 2011 8:34 am |
