It is currently Fri Jul 11, 2025 11:56 pm
Reply to topic  [ 7 posts ]
 possible solenoid problem?
Post possible solenoid problem?
I have a 9hp Honda engine on a go devil frame. I was driving my boat the other night and saw a spark come from down near the solenoid/ starter area. Immediately after that my engine would not start with the electric start, wouldn't even click. I can start it if i trip the solenoid with a screwdriver or use the pull start of course. I replaced the solenoid and can still do the same but cannot start the engine with a key. Any suggestions? Also is it possible I am using to powerful of a battery? I am using a deep cycle battery from my old outboard engine but it is a pretty new battery.
Mon Jan 02, 2012 4:38 pm
Post Re: possible solenoid problem?
Sounds like either a ignition bad wire or bad solenoid.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Mon Jan 02, 2012 4:51 pm
My 23 did the same thing last week. It was a bad solenoid have you replaced the old solenoid?
Sent via telegraph
Mon Jan 02, 2012 4:53 pm
Just retread your post. If your current solenoid isn't bad its an ignition problem. Check and make sure all the wires are still hooked up in the back of the ignition(were you put the key)
Sent via telegraph
Mon Jan 02, 2012 4:55 pm
Fuse!
Mon Jan 02, 2012 4:57 pm
i will recheck the wiring and the fuses and repost if the problem still happens
Mon Jan 02, 2012 5:33 pm
key switch.
Mon Jan 02, 2012 9:00 pm
Users browsing this forum: No registered users and 105 guests
