It is currently Sat Jul 12, 2025 6:00 am
[ 7 posts ] |
possible solenoid problem?
tpj070
I have a 9hp Honda engine on a go devil frame. I was driving my boat the other night and saw a spark come from down near the solenoid/ starter area. Immediately after that my engine would not start with the electric start, wouldn't even click. I can start it if i trip the solenoid with a screwdriver or use the pull start of course. I replaced the solenoid and can still do the same but cannot start the engine with a key. Any suggestions? Also is it possible I am using to powerful of a battery? I am using a deep cycle battery from my old outboard engine but it is a pretty new battery.
Mon Jan 02, 2012 4:38 pm |
Team Camo
Joined: Thu Oct 01, 2009 4:49 pm Posts: 8536 Location: Bridge City, TX
 Re: possible solenoid problem?
Sounds like either a ignition bad wire or bad solenoid.
_________________ 1846 GTB & 35 GTR Team Gator-Tail
Killer Kallz & ANGLE PORT dealer (409) 720-8949
Mon Jan 02, 2012 4:51 pm |
hunt682
Joined: Tue Jan 27, 2009 9:43 am Posts: 1127 Location: Camilla, Georgia
My 23 did the same thing last week. It was a bad solenoid have you replaced the old solenoid?
Sent via telegraph
Mon Jan 02, 2012 4:53 pm |
hunt682
Just retread your post. If your current solenoid isn't bad its an ignition problem. Check and make sure all the wires are still hooked up in the back of the ignition(were you put the key)
Sent via telegraph
Mon Jan 02, 2012 4:55 pm |
cb5331
Fuse!
Mon Jan 02, 2012 4:57 pm |
tpj070
i will recheck the wiring and the fuses and repost if the problem still happens
Mon Jan 02, 2012 5:33 pm |
CAJUN OUTLAW
key switch.
Mon Jan 02, 2012 9:00 pm |
[ 7 posts ] |
Users browsing this forum: Google [Bot] and 95 guests |
