It is currently Mon Jul 14, 2025 1:42 pm
Reply to topic  [ 12 posts ]
 Rev Limiter
Post Rev Limiter
Can I put a electronic rev. limiter on a stock carb? Is there any benefits or neg. of doing this. I am running right around 4000 rpm wide open out of water. I have a purple gov. spring, but the thing that I don't like I have my gov. screw almost cranked tight. the spring that is around the screw looks like it is ready to pop off.
Motor: 2009 35hp. Briggs GoDevil Surface Drive
Boat: 2009 GoDevil 16X60
Mods: None for now
Sat Jan 14, 2012 11:48 am
Post Re: Rev Limiter
You already have a Rev limiter built into the motor. YOu do not need a external rev limiter besides the one you got. No benefit and no negative to adding one
Sat Jan 14, 2012 12:15 pm
If all your turning is 4000 oow, u need to crank that up to 4300 to give a lil more go. The spring will b fine.
18'x54"CC Hanko/ 36PD
Sat Jan 14, 2012 1:50 pm
^^^^ X2 ^^^^
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sat Jan 14, 2012 4:37 pm
Sat Jan 14, 2012 6:33 pm
I know but he said he has a stock motor which means he did none of that except change a spring out. I know how the rev limiter works, if his motor is stock then he didn't remove the govenor gear.
Sat Jan 14, 2012 9:21 pm
Sat Jan 14, 2012 11:46 pm
OF course you can, but what the hell for? A stock motor is not gonna reach a critical RPM, so why would you put a external rev limiter on it......Wow...come on DB8, aren't you SUPPOSE to be some kind of MM guru.
Sun Jan 15, 2012 6:12 am
Sun Jan 15, 2012 6:55 am
U did a good job of explaining that DB8.
Sun Jan 15, 2012 6:56 pm
Post Rev Limiter
Oh snap!! Lol
Sun Jan 15, 2012 6:58 pm
Wow thanks guy's for the info.
Garry I have my throttle set right and I will just get the brown spring and go from there. Thanks for the great info.
Mods: None for now
Fri Jan 20, 2012 8:01 am
Users browsing this forum: No registered users and 112 guests
