It is currently Fri Jul 11, 2025 9:47 pm
Reply to topic  [ 10 posts ]
 GT Trim Problem
Post GT Trim Problem
Okay guys, ive got a question for yall. i have a 2004 GT 27 and the other day i took it to the river and it ran great and trim worked flawlessly. the next day i took the motor off the boat due to high water levels so i could put my outboard on. well after i took it off the boat and put it on the motor pallet i had built, i went to trim the motor down on the pallet and it wouldnt work? i know its not electrical due to the fact that when i would hit the trim button, the trim hydraulic would kick on and load up like its working but i got zero movement. same result for trimming up and down. sounds like its working and loading up but no actual result???? i looked and have no fluid leak or any sign of problem? im now lost at what to do or try, any suggestions? or solutions? anything at this point helps! thanks
1750 DeadFowl Custom with a GTR 37EFI
Build Thread: http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=62923
Wed Feb 22, 2012 2:37 pm
Post Re: GT Trim Problem
Purge out old hydraulic fluid and fill back up, could be low. Also must be mounted in the upright position to work. Laying on its side on a pallet it will not work.
Wed Feb 22, 2012 3:33 pm
the pallet was special made to sit upright. it bolts on a 2x8 like mounting to transom. and okay ill give it whirl and see what happens! thanks for the advice!
Wed Feb 22, 2012 6:01 pm
If it was working before u took it off, then I would say something got bumped in the process of the removal. Make sure connections are secure and have a good ground
Thu Feb 23, 2012 10:37 pm
I had this exact same problem recently. As mentioned above I had to purge out the old oil and refill and it worked like a champ! Might have a small leak that you cant see. I noticed oil on the transom of my boat, but yet to find a leak on the ram anywhere.
16x60 GD Tank with a 35 GDSD
Fri Feb 24, 2012 8:28 am
Fri Feb 24, 2012 9:45 am
gotta hook it back to the battery! :roll:
Fri Feb 24, 2012 11:10 am
Fri Feb 24, 2012 3:31 pm
X2 on draining the oil and replacing it. If you can't move it by hand after draining the fuids, there is a purge screw on the back, take that out and that fluid should unlock the ram
Fri Feb 24, 2012 6:31 pm
thanks guys! when i get time to get back up to the shop, ill see what i can do!
Sat Feb 25, 2012 11:10 pm
Users browsing this forum: Google [Bot] and 107 guests
