swanger011
Joined: Thu Jan 27, 2011 4:22 pm Posts: 260 Location: North East, Tx
 GT Trim Problem
Okay guys, ive got a question for yall. i have a 2004 GT 27 and the other day i took it to the river and it ran great and trim worked flawlessly. the next day i took the motor off the boat due to high water levels so i could put my outboard on. well after i took it off the boat and put it on the motor pallet i had built, i went to trim the motor down on the pallet and it wouldnt work? i know its not electrical due to the fact that when i would hit the trim button, the trim hydraulic would kick on and load up like its working but i got zero movement. same result for trimming up and down. sounds like its working and loading up but no actual result???? i looked and have no fluid leak or any sign of problem? im now lost at what to do or try, any suggestions? or solutions? anything at this point helps! thanks
_________________ 1750 DeadFowl Custom with a GTR 37EFI Build Thread: http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=62923
Wed Feb 22, 2012 2:37 pm |
quackconsumer
 Re: GT Trim Problem
Purge out old hydraulic fluid and fill back up, could be low. Also must be mounted in the upright position to work. Laying on its side on a pallet it will not work.
Wed Feb 22, 2012 3:33 pm |
swanger011
 Re: GT Trim Problem
the pallet was special made to sit upright. it bolts on a 2x8 like mounting to transom. and okay ill give it whirl and see what happens! thanks for the advice!
Wed Feb 22, 2012 6:01 pm |
take'emgator
Joined: Mon Oct 19, 2009 6:38 pm Posts: 10201 Location: SETX
 Re: GT Trim Problem
If it was working before u took it off, then I would say something got bumped in the process of the removal. Make sure connections are secure and have a good ground
Thu Feb 23, 2012 10:37 pm |
CypressIslandBoyy
Joined: Tue Jan 13, 2009 9:00 pm Posts: 131 Location: Morgan City, LA
 Re: GT Trim Problem
I had this exact same problem recently. As mentioned above I had to purge out the old oil and refill and it worked like a champ! Might have a small leak that you cant see. I noticed oil on the transom of my boat, but yet to find a leak on the ram anywhere.
_________________ 16x60 GD Tank with a 35 GDSD
Fri Feb 24, 2012 8:28 am |
swanger011
 Re: GT Trim Problem
Fri Feb 24, 2012 9:45 am |
CLICKSTER
 Re: GT Trim Problem
gotta hook it back to the battery!
Fri Feb 24, 2012 11:10 am |
elebouef102
 Re: GT Trim Problem
Fri Feb 24, 2012 3:31 pm |
sela_native
 Re: GT Trim Problem
X2 on draining the oil and replacing it. If you can't move it by hand after draining the fuids, there is a purge screw on the back, take that out and that fluid should unlock the ram
_________________ 1650 ribbed abused by a Gt-35 and push pole reverse
Fri Feb 24, 2012 6:31 pm |
swanger011
 Re: GT Trim Problem
thanks guys! when i get time to get back up to the shop, ill see what i can do!
Sat Feb 25, 2012 11:10 pm |
