daddymallard
 Roller Rocker Question
About to pull the trigger and order iron mtn heads and high rev coils. I already have a mikuni and MM exhuast on a 2011 36PD. My question is that is it worth it to go ahead and get the 1.5/1 roller rockers and heavy push rods or wait>??????
_________________ 1854 Brotha Breaux chased by 36 PD!
Wed Feb 29, 2012 2:54 pm |
BoatDR
 Re: Roller Rocker Question
I only recomend them when you install a cam. Not necessary if you are only doing heads, although it wont hurt to have them.
Wed Feb 29, 2012 3:00 pm |
daddymallard
Thanks Doc!!!!!
Wed Feb 29, 2012 4:20 pm |
schmitt
Joined: Fri Jun 25, 2010 3:33 pm Posts: 1177 Location: WI
why are they needed for the cam if you dont mind me asking?
_________________ 1848 DeadFowl pushed by a Stage 4 Delta powered MB HDR (JBP dusting)
Wed Feb 29, 2012 4:51 pm |
BoatDR
First of all, I didnt say it was needed, just that I recomend it.
And the reason that I do, is that a performance cam has more travel/higher lift. Thus it compresses the valve spring more putting more stress on the rocker arm/push rod, and both the aftermarket roller rockers and push rodsare substancially larger/stronger than the stock ones.
Wed Feb 29, 2012 5:23 pm |
WestEndAngler
MMT Moderator
Joined: Thu Mar 05, 2009 9:11 am Posts: 9143 Location: Houston | Surfside
I had stock rods & rockers in mine, made it 100 yards before one fell out  swapped in a set and never looked back.
_________________ GTB 1860 w/ 2019 GTR40XD-HO
Wed Feb 29, 2012 6:31 pm |
craig
Stock push rods are all I use.
They're good to 5300+ rpm.
Wed Feb 29, 2012 7:22 pm |
msm8281
Joined: Fri Oct 09, 2009 1:50 pm Posts: 9673 Location: New Iberia, La.
Wed Feb 29, 2012 7:25 pm |
craig
All I run are Stage 3 motors.
Wed Feb 29, 2012 8:17 pm |
schmitt
Sat Mar 03, 2012 9:35 am |
