It is currently Sat Jul 12, 2025 3:29 pm
Reply to topic  [ 10 posts ]
 Roller Rocker Question
Post Roller Rocker Question
About to pull the trigger and order iron mtn heads and high rev coils. I already have a mikuni and MM exhuast on a 2011 36PD. My question is that is it worth it to go ahead and get the 1.5/1 roller rockers and heavy push rods or wait>??????
1854 Brotha Breaux chased by 36 PD!
Wed Feb 29, 2012 2:54 pm
Post Re: Roller Rocker Question
I only recomend them when you install a cam. Not necessary if you are only doing heads, although it wont hurt to have them.
Wed Feb 29, 2012 3:00 pm
Thanks Doc!!!!!
Wed Feb 29, 2012 4:20 pm
why are they needed for the cam if you dont mind me asking?
1848 DeadFowl pushed by a Stage 4 Delta powered MB HDR (JBP dusting)
Wed Feb 29, 2012 4:51 pm
First of all, I didnt say it was needed, just that I recomend it.
And the reason that I do, is that a performance cam has more travel/higher lift. Thus it compresses the valve spring more putting more stress on the rocker arm/push rod, and both the aftermarket roller rockers and push rodsare substancially larger/stronger than the stock ones.
Wed Feb 29, 2012 5:23 pm
MMT Moderator
I had stock rods & rockers in mine, made it 100 yards before one fell out :lol: swapped in a set and never looked back.
GTB 1860 w/ 2019 GTR40XD-HO
Wed Feb 29, 2012 6:31 pm
Stock push rods are all I use.
They're good to 5300+ rpm.
Wed Feb 29, 2012 7:22 pm
Wed Feb 29, 2012 7:25 pm
All I run are Stage 3 motors.
Wed Feb 29, 2012 8:17 pm
Sat Mar 03, 2012 9:35 am
Users browsing this forum: No registered users and 117 guests
