It is currently Sat Jul 12, 2025 7:15 pm
Reply to topic  [ 60 posts ]  Go to page 1, 2  Next
 Prodrive manual reverse not working HELP!
Post Prodrive manual reverse not working HELP!
Just bought a used prodrive 36. And not to mention poor Maintenance. The locking pin on the reverse does not lock in to place to rotate it back around. Help what the problem!?
2072 Gatortail extreme with dual 35s GTRs
Thu Feb 02, 2012 6:05 pm
Post Re: Prodrive manual reverse not working HELP!
pull the pin out and see if something is in the spring
Thu Feb 02, 2012 6:10 pm
The pin itself is easily able to be pulled. The spring inside allows the pin to be pulled out and retract but when I push motor to the side to pull the pin it just feels like there is nothing for it to lock into.
Thu Feb 02, 2012 6:15 pm
Pull pin and push handle...it should rachete around... there is a tensioner screw that holds lu so it dosent turn back with the handle.
Black ops IITX marshstalker
1840 WC www.wccustomboats.com
fuel injected 25 GTR
Thu Feb 02, 2012 6:20 pm
I tried just pulling pin and ratcheting motor but still nothing. It just continues to freely pivot like I'm steering
Thu Feb 02, 2012 6:24 pm
It work when you went to buy it or did ya not try it?
1850 & 36pd
Thu Feb 02, 2012 6:27 pm
It was a great price so I had it shipped to me. Everything else works except that.
Thu Feb 02, 2012 6:36 pm
is the lower unit turning when you turn the handle, or just the engine??
Thu Feb 02, 2012 6:37 pm
Lower unit turns no matter if pin is pulled or not
Thu Feb 02, 2012 6:47 pm
Pull the pin and move the Lu with your foot
Thu Feb 02, 2012 6:50 pm
Will that break it free?
Thu Feb 02, 2012 6:53 pm
tighten the black knob on the lower unit and see if it still spins when you pull the pin
Thu Feb 02, 2012 7:03 pm
Make sure the tension knob is snug.
Thu Feb 02, 2012 7:04 pm
you need a little mud or something to hold the lower unit in place. Mine doesn't do so well trying to just put it in reverse from the boat. But when the skeg is held by a little pressure, it works fine. Have a buddy hold it or tie the LU off to something.
HOTSAUCE170 wrote:
Thu Feb 02, 2012 7:05 pm
Thu Feb 02, 2012 7:07 pm
Just relatized that above that black knob there is a threaded hole, it looks like a bolt goes in there. My motor has no bolt in it, pretty sure it's important, does it affect the reverse
Thu Feb 02, 2012 7:43 pm
Thanks guys! I got it! Now where is the lower unit drain plug and where is the fill plug, and how much oil?
Thu Feb 02, 2012 7:51 pm
Go to prodrives website and look at the owners manual
Thu Feb 02, 2012 7:54 pm
you prob. won't ever find the upper plug for the 90 wt. if you don't look at the manual.
Thu Feb 02, 2012 8:04 pm
Thanks guys! You all really helped me Alot!
Thu Feb 02, 2012 8:17 pm
Thu Feb 02, 2012 8:18 pm
Glad you got it figured out and that its not jacked up
1850 & 36pd
Thu Feb 02, 2012 8:24 pm
I will post a pic of the bolt hole soon, really appreciate it guys!
Thu Feb 02, 2012 8:45 pm
I have had this happen before if the bolt just in front of the pin lock is new or looks new then that is the reason that it does not work. if that bolt breaks while the previous owner is trying to go into reverse it will brake the locking pin for the reverse. Some times the handle will fall out and will need replacement. But if they cought it in time the pin is sheared and needs replacement. Unlock the allen screw just above the black handle and turn the threaded insert just above it like unscrewing a bolt this will allow the pin to fall out and at this point you can see what is going on with the locking pin look in the hole with a light. Hope this helps.
Thu Feb 02, 2012 9:21 pm
You just have to put a little snap into the handle when you attempt to rotate the LU. If you just move the handle back and forth it won't work.
18x48 Charles Leonard / 36PD
Thu Feb 02, 2012 9:37 pm
Then after you figure it all out, go to www.mudmotorstore.com and buy the reverse pin puller.
Thu Feb 02, 2012 9:57 pm
I will check to make sure the pin hasnt been replaced. It sounds like that may be what happened. Though i did get the LU to turn into reverse, so at least can get her turned around but i still think it isnt working 100%.
im adding a pic that i questioned earlier, just so i know what it is exactly so when i call prodrive they know what i need
Fri Feb 03, 2012 6:20 am
The hole in question is in between the black knob and the reverse pin. I love these forums you guys been a big help.
Fri Feb 03, 2012 6:22 am
The black knob is your tension adjuster. Make sure you grease your reverse fittings. They are on the back of the motor, behind the muffler, one is underneath the clutch mounting plate and one on top (probably right behind the black clutch cover). As you rotate the lower unit into reverse, you want to put 2 shots of grease in both fittings each time the pin clicks as you turn it.
Fri Feb 03, 2012 10:29 am
Thanks Wilson! Do you know what that missing bolt I am talking about is? The hole above the black knob in my pic?
Fri Feb 03, 2012 10:55 am
That hole on my lu is capped...its got from the factory a round plate the size of a quarter over where your hole is......there are two allen screws on the opposite side of lu and a grease fitting.
Fri Feb 03, 2012 11:03 am
Great ill get prodrive to send me that... AND A MANUAL! Not one of the fitting o
This motor has not been greased a a good 2 years. I'm lucky nothing else was damaged. Sad seeing these awesome motor neglected.
Fri Feb 03, 2012 11:15 am
dont take much to squirt a little grease after rinsing her off to put up....
Fri Feb 03, 2012 12:51 pm
Exactly. It so easy to do but if you don't you ruin your investment.... Well my motor is my investment somehow lol
Fri Feb 03, 2012 1:19 pm
Don't grease a PD after ever trip
Every 25 hours
Fri Feb 03, 2012 1:20 pm
Fri Feb 03, 2012 2:53 pm
I definately was not going to run it unroll the hole was plugged. I'm guessing that is where I would add lower unit oil
Fri Feb 03, 2012 6:42 pm
You can run it like that.
Fri Feb 03, 2012 6:43 pm
No way?! Really then water will get into the upper end of the lower unit?!
Fri Feb 03, 2012 6:50 pm
yeah, its not a totally sealed lower unit. Turn your motor on its side and 90 wt. will run out where the clutch meets the lower unit. And that missing bolt is on the outside swivel housing anyway right? That hole will not lead to the inside of the LU. Prob put a grease zerk in it.
Fri Feb 03, 2012 7:12 pm
Users browsing this forum: No registered users and 95 guests
