It is currently Sun Jul 13, 2025 1:12 pm
Reply to topic  [ 15 posts ]
 Cam Install. Couple Questions.
Post Cam Install. Couple Questions.
While I have this beauty apart, I was gonna cut the Governor Tab off. I've seen it done in the other Cam Install posts, but what do you use to cut it? A Dremel type tool?
What do you wash the inside of the motor down with to make sure all the shavings would be out of the block.
Thu Mar 29, 2012 11:50 am
Post Re: Cam Install. Couple Questions.
just leave it in there and lock it in place so it doesn't move.
Thu Mar 29, 2012 11:51 am
First of all, I dont think anyone would cut it while it is installed in the block (because of the shavings). And second, if you are going to take it out, I would suggest to simply remove it and put a bolt in its place.
Thu Mar 29, 2012 11:59 am
Post Re: Re: Cam Install. Couple Questions.
Thu Mar 29, 2012 12:30 pm
Ok. Looking at this photo, I assumed the Governor was cut where it sits, since it wasn't removed altogether.
Thu Mar 29, 2012 1:31 pm
There is just a snap ring that holds it in place. So if you remove the BeePeeSss governor lock in your first pic, and remove the snap ring below it, is simply slides right out..........then you can cut it, grind it, you can even eat it if you want, then re-install it.
If you want to remove it completly, I'll give you a list of what needs to be done and parts needed to do so.
Thu Mar 29, 2012 2:27 pm
Take it out copmpletly and just put a small bolt their instead
Thu Mar 29, 2012 3:21 pm
Or install a core plug.
Fri Mar 30, 2012 8:44 am
oh man! I sure hope we haven't seen the slowdevil run for her last time!!! :D
Fri Mar 30, 2012 11:28 am
Fri Mar 30, 2012 12:08 pm
1754 GTB / 35 GTR
Fri Mar 30, 2012 12:19 pm
Another question.
Shouldn't I crank the motor before putting the lower unit back on to make sure everything is sealed and running right?
Fri Mar 30, 2012 3:58 pm
I would
Fri Mar 30, 2012 4:18 pm
Fri Mar 30, 2012 8:45 pm
Users browsing this forum: No registered users and 123 guests
