bbb
Joined: Wed Sep 02, 2009 2:54 pm Posts: 1554 Location: SW Georgia
 Cam Install. Couple Questions.
While I have this beauty apart, I was gonna cut the Governor Tab off. I've seen it done in the other Cam Install posts, but what do you use to cut it? A Dremel type tool?
What do you wash the inside of the motor down with to make sure all the shavings would be out of the block.
_________________ 19x54 Seminole Extreme with a 35hp CDI GDSD. Mikuni. Marsh Mellow. Heads. Cam.
Thu Mar 29, 2012 11:50 am |
dguidry
Joined: Tue Jun 29, 2010 1:20 pm Posts: 11166 Location: Cecilia, LA
 Re: Cam Install. Couple Questions.
just leave it in there and lock it in place so it doesn't move.
_________________ Formerly:1648 Homemade Cypress Crawfish Skiff GTR23 Performance Cam and Heads; 17x46 Gator Tail with 35GTR and Hoyt's cam;s Currently: 17x48 Gator Tail with XD40 EFI. “Wisdom is not just expertise. It is knowing how much of various areas of expertise you need to know in order to make the decisions that the world needs and that you want to do,” Columbia University President Lee Bollinger.
Thu Mar 29, 2012 11:51 am |
BoatDR
First of all, I dont think anyone would cut it while it is installed in the block (because of the shavings). And second, if you are going to take it out, I would suggest to simply remove it and put a bolt in its place.
Thu Mar 29, 2012 11:59 am |
cb5331
 Re: Re: Cam Install. Couple Questions.
Thu Mar 29, 2012 12:30 pm |
bbb
Ok. Looking at this photo, I assumed the Governor was cut where it sits, since it wasn't removed altogether.
Thu Mar 29, 2012 1:31 pm |
BoatDR
There is just a snap ring that holds it in place. So if you remove the BeePeeSss governor lock in your first pic, and remove the snap ring below it, is simply slides right out..........then you can cut it, grind it, you can even eat it if you want, then re-install it.
If you want to remove it completly, I'll give you a list of what needs to be done and parts needed to do so.
Thu Mar 29, 2012 2:27 pm |
fowl habbit
Joined: Sat Jan 16, 2010 1:52 pm Posts: 1130 Location: THE ONE AND ONLY BUFFALO COUNTY
Take it out copmpletly and just put a small bolt their instead
Thu Mar 29, 2012 3:21 pm |
50fps
Or install a core plug.
Fri Mar 30, 2012 8:44 am |
Choclab
oh man! I sure hope we haven't seen the slowdevil run for her last time!!!
Fri Mar 30, 2012 11:28 am |
bbb
Fri Mar 30, 2012 12:08 pm |
NFW
Joined: Tue Jul 13, 2010 5:45 pm Posts: 625 Location: North Florida / Jackson, MS
_________________ 1754 GTB / 35 GTR
Fri Mar 30, 2012 12:19 pm |
bbb
Another question.
Shouldn't I crank the motor before putting the lower unit back on to make sure everything is sealed and running right?
Fri Mar 30, 2012 3:58 pm |
BoatDR
I would
Fri Mar 30, 2012 4:18 pm |
cb5331
bbb
Fri Mar 30, 2012 8:45 pm |
