Barroll
Joined: Fri Jan 15, 2010 10:19 am Posts: 932 Location: Georgia
 Cam swap.....bad noise
I just put a BPS cam in my motor. I took the governor shaft and gear out, set valves, etc. When I crank the motor it makes a whining sound. I am unsure of where this sound is coming from. I dont believe it is coming from the cam. Could it be a bad bearing in the crankcase cover? Has anyone ever had this happen? Thanks
_________________ 1848 Prodigy 35 GTR
Mon Apr 30, 2012 10:23 am |
Barroll
 Re: Cam swap.....bad noise
no body has any ideas on what this could be?
Tue May 01, 2012 12:58 pm |
craig
Never experienced this issue.
Is it possible to post a vid of it?
Tue May 01, 2012 1:30 pm |
Calen
Did you check for thrust ?
_________________ Calen's Engine Service 337-578-4434
Tue May 01, 2012 1:44 pm |
MaXXis85
Tue May 01, 2012 1:52 pm |
deadbird8
Tue May 01, 2012 6:32 pm |
autogateman
I heard of it once when the bolt blocking off the gov gearshaft hole was a lil too long and was rubbing the gears
Tue May 01, 2012 6:35 pm |
cb5331
 Re: Re: Cam swap.....bad noise
Tue May 01, 2012 6:51 pm |
Barroll
Tue May 01, 2012 9:44 pm |
cb5331
You did put assembly lube on everything you could get your hands on while you were in there, right? How long has the motor run? Long enough to get a good coat of oil on everything?
Tue May 01, 2012 9:48 pm |
Barroll
Tue May 01, 2012 10:28 pm |
MaXXis85
You installed the parts right? Why not see if you can figure it out? Pop the sump cover off and see whats up.
Wed May 02, 2012 5:46 am |
craig
Your issue is more than likely coming from outside of the engine...such as the drive itself.
Wed May 02, 2012 7:18 am |
Barroll
Wed May 02, 2012 7:35 am |
Barroll
craig
Then you def. have a problem.
Wed May 02, 2012 7:55 am |
schmitt
Joined: Fri Jun 25, 2010 3:33 pm Posts: 1177 Location: WI
_________________ 1848 DeadFowl pushed by a Stage 4 Delta powered MB HDR (JBP dusting)
Wed May 02, 2012 8:06 am |
Barroll
Wed May 02, 2012 8:11 am |
Barroll
Wed May 02, 2012 8:12 am |
cb5331
Wed May 02, 2012 3:58 pm |
Barroll
Wed May 02, 2012 9:07 pm |
cb5331
Thank you, Cody.
Wed May 02, 2012 9:14 pm |
MaXXis85
Thu May 03, 2012 5:48 am |
duckduckboom
Joined: Tue Nov 23, 2010 6:33 pm Posts: 5603 Location: Corner of Hell an high water, La
I'll admit, I said it out loud to get the full effect
_________________ You have your whole life to be an idiot, take a day off!
Thu May 03, 2012 6:03 am |
CLICKSTER
me too!^^^
Thu May 03, 2012 6:06 am |
richard nagon
autogateman and other engine builders on this site. why would u stick a bolt with washers lock washers locking nuts and sealer. when all u have to do is take a pipe tap and tap it and use a pipe plug. ? a much better fix and alot safer.
_________________ JUST ANOTHER FARMER ON WELFARE
Thu May 03, 2012 6:02 pm |
cb5331
Thu May 03, 2012 6:47 pm |
cb5331
Now that I typed that out, I guess you could put a cup under the hole to catch em.  still, that was the reason I was given.
Thu May 03, 2012 6:48 pm |
Gator Guy
Joined: Tue Jan 13, 2009 4:53 pm Posts: 457 Location: Loreauville
Thu May 03, 2012 8:15 pm |
richard nagon
so when it comes out of the bottom of the gov. shaft bore due to vibration and heet. it looks good. ?
Thu May 03, 2012 8:23 pm |
Gator Guy
Fri May 04, 2012 6:22 am |
Barroll
Fri May 04, 2012 9:02 am |
cb5331
Barroll, what's the deal? Fix it?
Tue May 08, 2012 3:43 pm |
dfou
Joined: Sun Dec 12, 2010 12:38 am Posts: 3986 Location: Pville, La
Any updates?
Wed Jul 04, 2012 9:42 pm |
DirtNasty
Joined: Fri Jun 03, 2011 7:55 am Posts: 221 Location: Bullard, TX
Thu Jul 05, 2012 12:26 pm |
