It is currently Mon Jul 14, 2025 12:54 am
Reply to topic  [ 16 posts ]
 gatortail question
Post gatortail question
I was wondering if anyone knows why sometimes when i switch from start to forward on my GTR it kills. I know it is something stupid but i just don't know. I have looked in the search box and could not find the answer i was looking for.
Mon Apr 30, 2012 7:58 pm
Post Re: gatortail question
Is your prop sitting in mud
No, it does it mostly right when i launch the boat. Could my rpm's be to low. My friend said something about a tab that needs to be bent or something. No clue, it only happens for a liitle while then its fine.
Mon Apr 30, 2012 8:06 pm
Like when it is cold
Mon Apr 30, 2012 8:07 pm
I mean Idle to low
Mon Apr 30, 2012 8:08 pm
1200 in neutral
Mon Apr 30, 2012 8:09 pm
What does it idle at? Most stock motors should idle okay in the 12-1300 range in neutral and 1000-1100 in gear. Improperly set or leaking valves can cause some idle issues, but check and see what your rpm's are first.
Mon Apr 30, 2012 8:11 pm
1500 neutral, and i will go from like 800 to 700 in gear
Mon Apr 30, 2012 8:13 pm
I adjusted the idle yesterday and got it back to normal. I was just curious about the killing issue
Mon Apr 30, 2012 8:15 pm
Yeah sounds like you need to adjust some valves an see if that helps
But would that aways occur if the valves were not sitting right. It only occurs right from the launch and my friend who has a GTR as well says it happens to his sometimes.
Mon Apr 30, 2012 8:31 pm
mine is idle about 960 and 875 in water flip it in gear and run it like tou stole it but after you check your valves
Mon Apr 30, 2012 10:38 pm
Most likely it's leaky or improperly adjusted valves. Set the valve lash to .005 & see if it gets any better.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Mon Apr 30, 2012 11:53 pm
Check valve lash.
Tue May 01, 2012 5:51 am
Tue May 01, 2012 6:12 am
Users browsing this forum: No registered users and 69 guests
