It is currently Wed Jul 16, 2025 1:50 am
Reply to topic  [ 12 posts ]
 Smoking motor
Post Smoking motor
Not a mm but a lawnmower engine nonetheless. I bought a mint john degree riding mower that had set up for a couple yrs that a buddy didn't use. Probably only used a couple seasons. Anyway when he brought it over it smoked like a mother. It resembled a dry ice machine at the local disco. Told him I couldn't buy it so he took it and got it serviced. The mower shop said likely a fuel issue due to setting up and the smoke was white. So he brought it back and it gives off just a hint of smoke at startup and goes away. If it's sets and idles tho it will do it a little then. So I used it maybe 6-8x. I checked the oil yesterday before using and it barely even hit the stick. Starts and runs great but I need to solve this issue before I burn the bastard up. It's a 15hp motor. Any help would be appreciated.
1850 & 36pd
Wed May 09, 2012 11:41 am
Post Re: Smoking motor
my guess is its burning oil from your discription! :shock:
Wed May 09, 2012 11:52 am
sounds like it needs a new set of rings, Charley. Did you check the oil when you acquired it and was it full?
HOTSAUCE170 wrote:
Wed May 09, 2012 11:57 am
Yeah when he took it in they flushed the fuel lines, new gas and gas line, oil change..etc. That something I could limp through summer with and keep an eye on the oil or does it need to be done pronto?
1850 & 36pd
Wed May 09, 2012 12:12 pm
If it is INDEED consuming oil , just check the levels each time you mow. is it a Briggs motor on it?
Wed May 09, 2012 12:15 pm
Just keep oil in it and run it. That's what most n1ggers do with their cars
Wed May 09, 2012 12:18 pm
if its burning oil it probably needs a valve job.
is the smoke bluish white?
________________________________
1754 Excel F4 .125 w/ Black Death 4200
Wed May 09, 2012 12:42 pm
Wed May 09, 2012 2:35 pm
Wed May 09, 2012 8:16 pm
Post Re: Re: Smoking motor
1850 & 36pd
Wed May 09, 2012 8:56 pm
That's a good sign. It means you still have oil. When it stops smoking,worry
Wed May 09, 2012 8:59 pm
If it sat for a while and has horizontal cylinders it could have had a little moisture in there which will leave a slight rust groove in the cylinder which the rings can't totally seal. It will run great and foul plugs a little more as long as you keep oil in it. Maybe switch to a heavier oil or start adding STP.
Thu May 10, 2012 2:17 am
Users browsing this forum: Google [Bot] and 108 guests
