It is currently Wed Jul 16, 2025 7:16 pm
Reply to topic  [ 22 posts ]
 compression ratio
Post compression ratio
Has anybody here figured what the compression ratio with iron mountain heads is? And what it is with bps rods and pistons?
Sat May 19, 2012 11:06 pm
Post Re: compression ratio
I just put one together with IM heads, PVT rods, & milled stock pistons. 205 - 215
Sat Jun 23, 2012 9:17 am
^ that isn't a ratio
Sat Jun 23, 2012 9:28 am
I have 160 psi with iron mountain heads, bps cam with stock pistons and rod's. If that helps at all
Sat Jun 23, 2012 9:54 am
i was looking for a ratio, like 10:1 for example..
Sat Jun 23, 2012 10:01 am
Tulip cut valve?
Sat Jun 23, 2012 5:37 pm
I suppose for a guess 10:1 wasn't too far off lol... thanks thats exactly what I was looking for, needed it to troubleshoot fuel problems.
Sat Jun 23, 2012 10:37 pm
Sun Jun 24, 2012 8:09 am
Thanks. A handful of us were running heads decked that much and some with a little more with stock internals and a cam with decent results a few years back.
Mon Jun 25, 2012 6:32 am
Mon Jun 25, 2012 10:16 am
Tue Jun 26, 2012 7:48 am
Well that's a good reason it wouldn't cooperate! I'm a little iffy about the reliability of a 10.9, some of my runs put me out in the middle of nowhere 50+ miles from nearest boat launch
Tue Jun 26, 2012 8:08 am
50hp, what would the compression ratio be of an engine using the billet pistons and rods that Al sells (0 deck height), with heads decked .020?
That's what my last build consisted of.
Although it went fast fast, it didn't last last.
Tue Jun 26, 2012 8:13 am
Make sure your pistons weight the same :-)
Tue Jun 26, 2012 11:19 am
Hey Cody you should post this on mb website.lol :lol: bet that would last about 2 seconds.
Sun Jul 22, 2012 10:39 pm
Oh boy
Mon Jul 23, 2012 6:08 am
THey still wouldn't understand even if posted over there, can't help someone that doesn't want to listen to reason.
Mon Jul 23, 2012 6:18 am
My last engine had compression numbers like that.
It ran great with the EVT intake but when using the BPS, AV gas was needed to prevent detonation....which is what ultimately led to it's demise.
Mon Jul 23, 2012 7:14 am
To much is too much
Mon Jul 23, 2012 7:32 am
Mon Jul 23, 2012 7:49 am
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Mon Jul 23, 2012 8:17 am
I've seen where many say 200 psi and above is really too much but these production motors are running 240 psi?
I looked up MB and they are at 4,300 feet, does that have anything to do with the higher psi? Are they not counting for the increased pressure difference from there to practically sea level?
Wed Jul 25, 2012 11:22 am
Users browsing this forum: No registered users and 87 guests
