It is currently Wed Jul 16, 2025 3:07 pm
Reply to topic  [ 7 posts ]
 Vapor Lock??
Post Vapor Lock??
Over the weekend I was running WOT and the engine would quit. I pulled the gas tank from under the deck and, even though the air valve was open, I noticed that the tank looked like it was dented(like air was sucked out of it). I thought maybe because of the 100 deg weather were having. I remove the fill cap and put it back on and it ran great after that.
I recognize it was probably vapor lock, but my question is are there better gas tank options out there. I have very little room under the deck and it is a really tight fit. Do they make lower profile, 6 gal tanks?
Mon Jul 09, 2012 9:34 am
Post Re: Vapor Lock??
Are you sure the air valve isn't plugged? That shouldn't happen if it's open fully no matter the temp. You could get a new cap with a vent and try it instead of a new tank.
Mon Jul 09, 2012 9:40 am
funny thing is I just put a new cap on because the air vent on the old one broke off and is under the floor. It broke off when I shoved it under the deck.
Mon Jul 09, 2012 9:49 am
Try the Moeller Marine tanks- they have lots of different shapes and sizes of tanks to fit a variety of applications. Or get on summitracing.com and look at the aluminum fuel cells. I had twin 6 gallon tanks that I replaced with a single 15 gallon Moeller Marine FT1598 tank, it takes up less room because I cut a small compartment under the front bench seat for it to fit into. Got it for $30 on craigslist :)
Mon Jul 09, 2012 12:08 pm
Mon Jul 09, 2012 1:44 pm
http://www.dansperformanceparts.com/bug ... yfuel1.htm
Mon Jul 09, 2012 4:00 pm
So this started with a new cap?
Mon Jul 09, 2012 4:05 pm
Users browsing this forum: Google [Bot] and 101 guests
