It is currently Wed Jul 16, 2025 3:42 pm
[ 7 posts ] |
mudder
Joined: Sun Jan 25, 2009 11:25 am Posts: 401 Location: Wisconsin
 Vapor Lock??
Over the weekend I was running WOT and the engine would quit. I pulled the gas tank from under the deck and, even though the air valve was open, I noticed that the tank looked like it was dented(like air was sucked out of it). I thought maybe because of the 100 deg weather were having. I remove the fill cap and put it back on and it ran great after that.
I recognize it was probably vapor lock, but my question is are there better gas tank options out there. I have very little room under the deck and it is a really tight fit. Do they make lower profile, 6 gal tanks?
_________________ Phowler Extreme 1848 with 36PDFPR
Mon Jul 09, 2012 9:34 am |
Will
 Re: Vapor Lock??
Are you sure the air valve isn't plugged? That shouldn't happen if it's open fully no matter the temp. You could get a new cap with a vent and try it instead of a new tank.
_________________ Before the internet, the majority of the village idiots stayed in their villages.
Mon Jul 09, 2012 9:40 am |
mudder
 Re: Vapor Lock??
funny thing is I just put a new cap on because the air vent on the old one broke off and is under the floor. It broke off when I shoved it under the deck.
Mon Jul 09, 2012 9:49 am |
vertical_edge_800
Joined: Thu Dec 30, 2010 5:48 am Posts: 274 Location: Palmer, Alaska
 Re: Vapor Lock??
Try the Moeller Marine tanks- they have lots of different shapes and sizes of tanks to fit a variety of applications. Or get on summitracing.com and look at the aluminum fuel cells. I had twin 6 gallon tanks that I replaced with a single 15 gallon Moeller Marine FT1598 tank, it takes up less room because I cut a small compartment under the front bench seat for it to fit into. Got it for $30 on craigslist
Mon Jul 09, 2012 12:08 pm |
mudder
 Re: Vapor Lock??
Mon Jul 09, 2012 1:44 pm |
50fps
 Re: Vapor Lock??
Mon Jul 09, 2012 4:00 pm |
Will
 Re: Vapor Lock??
So this started with a new cap?
Mon Jul 09, 2012 4:05 pm |
[ 7 posts ] |
Users browsing this forum: No registered users and 120 guests |
